- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
We've been having a discussion about radar installation in the Lucid Air under the "Safety Recall" thread (my fault, I admit). So I thought we should start a thread specific to this topic.
I picked up our car today after a 7-day installation job. The car was returned in perfect condition near as I can tell -- no squeaks, rattles, panel misalignments -- despite significant portions of the front and rear ends and the under-dash panels having been removed.
There were a couple of questions raised under the other thread:
Q: How did the build quality of the Air compare to what the installer has observed in other cars on which he's worked?
A: The build quality and engineering approaches appeared to be on par with other premium brands on which he's worked. The only exception was an unusually widespread use in the Air of Velcro for plastic panel and cover attachments in places other manufacturers would have used clips. He could not divine any reason why other than perhaps easier and speedier assembly, but he did have questions about the durability of such an approach.
Q: Why not a Stinger system instead of the Radenso?
A: The installer uses both systems. He prefers the Stinger system for certain exotics with highly-contoured and smooth fascias, as its fiber optic sensors require only 3-mm holes (one set of 3 holes in each side of the fascia). However, these sensors are not as effective in detecting signals as the bulkier AL Pilot sensors used by Radenso, plus he thinks the Radenso filtering algorithms are the best on the market.
Now, here are some photos of the installation:
Front Laser Sensors:
Rear Laser Sensors:
Front Radar Detector (rear detector is mounted behind the bumper cover):
Rear Laser Sensors:
