The estimate is based on the fixed assumption that your drive will achieve the EPA estimate for efficiency. But many factors will cause potential deviations from that estimate. Unfortunately, the software doesn't adjust in real time. Therefore, the longer your drive, the more you will likely deviate. If your trip is 20 miles, the estimate will probably be pretty accurate. If your trip is 400 miles, then not so much. This matters if you're relying on the nav to plan your next charge during a longer road trip.
