Post frontend repair bug
antonz
air gt 2025
The buf with stepped opening of the hood is happening to my air gt 2025 after the frontend repair disassembly and assembly.
It needs 4 clicks on the screen or inside-the-hood button to fully open. It never goes down "by button"
Pair of new struts have been tested and doesn't change anything.
The hood locks and actuators installed are from GT 2022 (aftermarket from a rear-damaged vehicle).
Any ideas about the reason?
Vehicle is still on 2.8.16 firmware with zero errors.
Who did the swap? Actually who did the repair?
The best one who was around taking into account where I am:D
My question is literally about this bug and the possible reasons
I asked as it may have been an error in the repair and not an actual bug of any sort
Yes, this can be. But which part/section this can be related?
OR, if somebody from service teams are here - is there the adaptation / calibration procedure for the hood after disassembly/assembly?
One or both of your latches may be misaligned.
There is no calibration procedure. I really suspect it’s your latches.
Thank you!
Do you suspect they should be lower/higher or the distance from the center (left/right) is wrong?
As I read over the internet - latches (or actuators, don't remember for 100%) from 2022 and late 2025 are different in terms of later ones are more waterproof.
But in terms of signals/electric parts/connection - they should be identical. If you know for sure - your input would be helpful too.
P.s. I have attached the video of what the display shows when opening the hood. The stop sign appears for the fraction of a second and the button continues to blink all the time with this stepped opening.
Thank you!
That part I do not know. You can also try adjusting the rubber spacers (I know, sounds ridiculous) on the hood, as we have seen that affect it in the past as well.
