- Apr 30, 2023
- Lucid Grand Touring
- WDATGN78
No problems with my 2022’s here.My gut statistical review is that later models (e.g. 2025's) are having fewer probelms,
The correct word is "brake" not "break".My one quirk after install: my car’s regenerative break setting was changed so that it didn’t stop all the way and would roll if I didn’t hit the break. Like at stop signs and lights. I changed the setting back but… am I the only one?
The follks in Natick are the best. Marcello always has a solution, either on the phone or with a visit to the SC.Good News Update! Went to Natick SC this PM & the sales team were able to reconnect my iPhone & get the car working as it should. Now behaving the best it ever has since we bought it. Haven't tried the driver assist features but otherwise is fine. So many problems are now gone. Thank you Natick.
I can't say enough good things about Marcello. He's been fantastic. One time he came and dropped off a loaner at my house and drove my car to Natick, and when he got there, he called me to let me know he identified an issue with the steering wheel that they were going to fix for me. I didn't even realize I had a problem, but once I got the car back, the steering feel was much, much nicer.The follks in Natick are the best. Marcello always has a solution, either on the phone or with a visit to the SC.
If you press down on the brake after stopping, does it engage hold?So it’s my stop mode setting, right above the creep setting that changed. I guess I’m the only one! Weird but manageable!
Ah, where is your sense of adventure!
Experienced collision warning disabled notification/warning..one or two days later the installation. Did the air reset.... warning remained for about 10 min even after the reset. It eventually went away.I'm still traumatized by 2.7.0 bricking the car every morning. Took me weeks of monitoring the thread to actually try 2.8.9... maybe I'll try this one by Christmas.
It wasn’t…One again hoping for a home charger throttling fix...
That’s it. You’ve got it.Clearly the software team is under-resourced and is basically just trying to squash bugs at this point. I'm guessing it's two guys with a Radio Shack computer who flilp a coin to figure out if they fix Gravity or Air today.
Please do.Update: DO NOT INSTALL 2.8.16.
Precise location (and background location, as a corollary) has always been required. Your proximity unlock issues seem coincidental. Have you let the car sleep?Robustness my freaking buttocks 2.8.16! It is more like Robust-Less .
That miles per kWh is a one time unicorn result due to battery being warmed up via the software update. The next day I got a stinking 2.85 Miles per kWh over a 80 mile trip which is Significantly worse then my usual 3.15 average lately. What's worse is Proximity UNLOCK. Proximity LOCK is fine and works reliably.
The Proximity UNLOCK is regressing to failure levels experienced pre 2.8.5, 2.8.7, or 2.8.9. It is back to the age where I have to take the phone manually out of my pocket and open the APP if needed. You also need to allow background location to always on the iOS Lucid App or it will drain 2-3 miles overnight due to location query in which will result with a no-ack from your phone. This will cause the Lucid App to query your location 80 times over the night.
I’ve had it for a little while with no issues.based on the reduced amount of activity on this update versus the last ones, i think i'm going to assume it's a relatively safe one to make? I've been holding off waiting for the comments hehe
This comment raises an interesting (at least to me) question. It suggests that Lucid may have the 'eyes-on' sensitivity set higher for Hands-Free Drive Assist than it does for Hands-On Drive Assist. I never thought that was the case. I have only used Hands-Free Drive Assist for a few miles since 2.8.16, and it did force me to take control, but the sun was low in the sky at the time, and I've noticed that Drive Assist doesn't like that. Is it possible that some conditions just happened to change at the same time that you switched hands-free off, or that you took off those dark sunglasses in your profile image?I eventually turned off hands free assist and just used plain vanilla lane keep assist and adaptive cruise control. It made for a far less stressful drive than fighting with hands free assist.
