Load Management for Lucid Home Charging Station
raj
Touring
Are there any load management systems that can throttle the charging speed of the Lucid Home Charging Station based on available capacity?
I have read about other brands that sell devices that work specifically with their own EVSE (such as Wallbox Pulsar Plus with power sensor accessory, for the Emporia Vue power meter which pairs with their charger), but I haven't found any third party solutions.
Last resort would be a power-cut load management system such as the DCC EV Energy Management System, but I would prefer to avoid that
thanks
Not sure what you are asking, or why.
If your circuit can't handle 80 amps charging you can reset the DIP switches inside the LUCID charger to reduce the load.
There are several setting to accomidate lower power circuits.
I am aware of the dip switches, but that would permanently limit the max current (the rating would even be listed with the town, so it couldn't be changed without pulling another permit). However, even though the NEC load calculations indicate my panel is nearly maxed out, in reality high loads only occur for relatively few hours in the year. A load management system would allow the car to draw 80 amps most of the time, but reduce the available amps if the panel approaches max load.
I think I should just buy a Wallbox Pulsar Plus with power sensor, since it is specifically designed for this scenario and seems to be the recommended solution. I was hoping to find something compatible with the Lucid charger because I already bought it and it is too late to return.
Before anyone suggests an upgrade to my electrical service, I have spent months exploring options. The electrics were all replaced during a gut renovation less than 10 years ago, and met code at that time, but the location of the panel does not meet current code. I can't make changes without moving the panel, which would be very disruptive in our house. I even considered a second service just for EV charging, because my local utility offers a Time of Use plan specifically for EVs that makes the MWh cost negligible at night, but meeting code was very challenging for our house, and the only place it could be installed was going to cost over $10k and result in placing the charger in an inconvenient location.
TLDR: strict code, old house, small lot and maxed out panel results in complicated installation, and I now know way more about my power supply than I ever had any desire to learn.
I use a Wallbox with Power Boost for this purpose as my secondary charger. There isn’t anything similar for the Lucid EVSE, which is my primary EVSE.
thanks for confirming, I suspected this was the case
I have only had my Air GT for a couple of days and am learning the differences after 10 years of Tesla Model S.
In answer to the question as to why anyone would want to throttle back the charging speed for home charging, which is a facility on the Tesla and remotely from their app, the answer, for us, is to maximise the benefit of charging from solar panels. Our electric coop changed away from net metering (long story involving influence from old oil) thus it behoves us putting all excess generation in the car when available. This may not be at maximum charge rate, and varies as the sun follows its daily path and weather gets in the way. The Tesla app makes this very easy, stopping and starting charging and altering the rate of charge, from the app wherever we may be. I am shocked Lucid does not have this facility, and I hope this will be made available in a future update.
Sounds like something they could do in software. Have you requested it to Lucid Customer Service?
I spoke to Customer Service today. They have raised a ticket. This may already be in the pipeline.
Reviving this old thread to see if the situation has changed in the last year.
I just looked at the online manual for the Lucid Connected Home Charging Station, and I still don't see any mention of EVEMS/load management capabilities. That's actually a bit disappointing, considering the premium price Lucid is asking for their charger.
My situation is that I'd like to install a charger at a location where the electrical service is already maxed out, and so I will need a smart load sharing solution if I want to be able to charge in that location.
It has not changed. I use a Wallbox Pulsar Plus as my second charger, with their “power boost” feature to lower it if needed. So LCHCS runs at 80A, Wallbox runs at 48A *or lower* depending on the current of the panel. So when both are running the LCHCS takes priority and when the LCHCS is done the Wallbox picks up the slack.
That’s probably your best option today if you need to load balance charging in real-time. The LCHCS doesn’t have that.
The LCHCS, at least current versions, supports OCPP 1.6J protocol. This can be used for load managing as well as load balancing between supporting charging stations. I’ve done a query in Grok. For anyone who wants to delve deeper into it.
I’m planning to use this with my 3 LCHCS stations that will be replacing my 3 Tesla wall connectors to load balance and share current.
I'm intrigued. But my situation is load managing within an oversubscribed electrical panel. For that I need a pretty rapid real time feedback loop that reliably responds to a big electric load turning on (e.g. induction range). Biting off the work to select hardware, deploy, and ensure real time response is more than I've got time for right now.
Wallbox seems like the easy off-the-shelf solution for me.
