Is there a way to up the amps when using level 1 charging?
Aren't those lines limited to 20 amp max? Either way, it all depends on the breaker you have for that line. Contact an electrician!Is there a way to up the amps when using level 1 charging?
Why? If you can bring in that many amps, why not do it with a 240 line?Is there a way to up the amps when using level 1 charging?
No there is no way to up it. The Lucid mobile cable with the 110V adapter cannot tell if it is on a 15A or 20A circuit. For safety it has to default to 80% of 15A, or 12A max.Is there a way to up the amps when using level 1 charging?
At first it was much lower. It looks like it self adjusted to 12 which is what I was looking for. My volt defaults to 8 but you can tell it to go to 12.No there is no way to up it. The Lucid mobile cable with the 110V adapter cannot tell if it is on a 15A or 20A circuit. For safety it has to default to 80% of 15A, or 12A max.
Exactly. I always saw a level one as a useful way to protect the battery from very cold weather by leaving it plugged in overnight.You are going to be plugged in constantly as you will only be pulling 1.3 kW. Per hour. The BMS consumes some of that so the full 1.3 kW is not going to enter the battery. On a 92 kW Touring battery, going from 20 to 80%, you will be adding 55 kW (even more on a GT) and probably only adding 1 kW an hour to the battery, so it would take over two days to charge the car - and even longer if the temps are very hot or cold which will cause the B!S to consume more of that power.While 110v works for PHEVs, it is really not a practical solution for this beast.
I’m only putting 20 miles per day. I think I’ll be OKYou are going to be plugged in constantly as you will only be pulling 1.3 kW. Per hour. The BMS consumes some of that so the full 1.3 kW is not going to enter the battery. On a 92 kW Touring battery, going from 20 to 80%, you will be adding 55 kW (even more on a GT) and probably only adding 1 kW an hour to the battery, so it would take over two days to charge the car - and even longer if the temps are very hot or cold which will cause the B!S to consume more of that power.While 110v works for PHEVs, it is really not a practical solution for this beast.
Oh man your Lucid is gonna be bored and lonely with that little driving!I’m only putting 20 miles per day. I think I’ll be OK
I got it to take long tripsOh man your Lucid is gonna be bored and lonely with that little driving!
