knocking sound above drivers front wheel well
The Millbrae service center fixed it in 30 min. A bolt on the suspension wasn't properly torqued from the factory and had to be tightened, which apparently they've seen a few times before. 3k miles since then and not a peep :)
Which car do you have? Our Pure makes the clunking noise pretty loudly and consistently. GT does not. This post gives me hope
This was a '24 Touring with about 8k on the odometer. Christopher Robinson aka based Millbrae service team GOAT identified the issue within 10 seconds of hearing it, and I'm sure would be happy to speak to your local service center if for some reason they're unaware of the trend.
Thanks for sharing.
I forwarded link to this thread to Lucid Service Center Customer Service and Repair technicians.
Hi – I honestly can’t stop dwelling on this. As previously mentioned, I was asked to drive my leased Air 4 hours to the nearest service center just to duplicate the suspension clunk in person, with no guarantee they’d keep it or provide a loaner. I did forget to mention that I waited over a month just to get that response, when I thought I was waiting for parts that were supposedly on order.
Why should I have to road trip my leased car just to get it looked at? Why should I have to road trip my car that’s having handling issues? I mean I’ve literally mentioned how it’s impossible to keep centered in my lane while driving down the highway - yet I’m asked to drive it 4 hours to the nearest service center?! I’ve already duplicated the issue numerous times, both in person and on video. If changing the struts didn’t fix it the first time, then I don’t know – maybe it’s time to look at and replace the steering rack, sway bar, wheel bearing, literally anything else?
Any suggestions on what I should do next or who I can contact? What do I need to do for this to be taken seriously? I really don’t want to be a Karen here, but I’m over halfway through my lease now and still haven’t been able to enjoy the ride. It handles terribly, and the suspension sounds like a toolbox orgy.
I regret leasing a Lucid at this point.
Hi, mustafam1.
Today, I took my 2023 Lucid Air Pure AWD in to Lucid service for the clunking noise heard on the left side of frontend suspension experienced over certain road conditions.
The technician got behind the wheel and I, in the passenger front seat of the car, and we drove around for at least 20 minutes trying to replicate the noise. However, no such luck.
I thought since I previously shared with Service Center and technical support team information about other Lucid owners having had similar experience, that car would be physically checked for whatever is causing this clunking noise. No. The technician wanted to hear the noise for himself (which I can fully understand and appreciate from his point of view). However, this still does not address the issue. So, I accepted the fact that when this condition occurs again, I will note the time, where and when I experience this clunking noise so that the next time I bring the car in for service, I will have a data point from which to complain and insist upon the technicians' further investigation.
Since the complaint is already on file and as experienced by other Lucid Air owners, I am less concerned as to what specific part in the frontend suspension is at fault. All I care about is that this condition should be investigated before it becomes a bigger issue. At the time I brought the car in, it may have appeared a minor item to the tech who told me that they were "busy", but I was not put off by the simple fact that I had an appointment and my complaint warranted the time and attention to identify and correct whatever the deficiency is in the front suspension. Suffice it to say, I will record the very next time I experience this noise and use the evidence with which to demand service technician put the car on a lift to physically exam adequacy of all integral parts therein, with or without a road test to try to replicate clunking noise.
Do not despair. This clunking noise I have experienced over certain road conditions is no joke. Neither am I. We paid good money for these cars. I will not except no less than the best both in the car's performance, which by the way, I am ecstatically pleased with, and in the service that we should all expect under warranty.
Stay tuned...
My apologies OP, I just realized this isn’t my thread 🤦‍♂️meant to post this elsewhere
I want to thank everyone who posted their experiences. I have 600 miles on my Touring and started hearing the noise yesterday. After doing a quick search on the forum and finding this thread I felt a lot better that I knew what the potential solution was.Called the service center, they got me in this morning and it took less than 10 minutes for them to do a quick test drive, then put it on the lift and tighten everything back up.
Of course I would’ve preferred to not have to go to the service center in the first place, but the experience was painless and the information provided in this thread gave me peace of mind that this could be a quick fix. Thank you again to everyone.
I had this same problem come up about 580 miles into my Lucid AT. The service advisor went on a short drive with me, immediately identified the rattling sound - evident when driving over uneven pavement - and had the car repaired within 1/2 day. Below is the service invoice summary:
Job: 1 Front Axle
Pay Type: Warranty
Concern: Customer reports a low rattling noise coming from under the car, specifically near the driver's seat by the left front tire
Cause: sway bar link nuts loose
Corrections: verified concern found front right sway bar link loose, replaced all four front sway bar links
I am recently experiencing the same thing! My car has about 30K
I'm experiencing a very similar issue on my 2025 Air Pure RWD (delivered in August 2024). The clunking noise only occurs when the front left tire hit uneven surfaces. The front right, on the other hand, has been super solid. No noise whatsoever. Video attached below: the car approached a dip on the road and made a noticeable clunking sound.
As a side note, I've had the vehicle for a little more than 4 months, and the car has been in the service center twice for a total of ~30 days (no loaner either). The second time it went back to the service center, they did take a look at the suspension noise issue but found nothing wrong. The technician was even nice enough to go out on a short drive with me to confirm the problem. Alas, the road around the NorCal Burlingame service center was actually quite smooth, and I only managed to make it happen once. The technician wasn't able to hone in on it.
Im experiencing the same issue, Were they able to identify the issue and fix?
I brought the car in the service center couple days ago without an appointment. Technician test drove and confirmed that the noise caused by‘sway bar’ but can’t work on it due to no lifts(?) available but assured that it is safe for me to drive. I am scheduled to bring the car next Tuesday to have the fixed. Fingers crossed
Got mine fixed last week. 2800 miles. Horrible rattle clunking started in the front passenger area. I thought something was rolling around the frunk, but there wasn’t.
Mobile tech came out and fixed it in 30 minutes. Loose sway bar. No need for a lift. Either there’s a design issue here or the sway bar torquer in Casa Grande stinks.
They are picking mine up to take it six hours to Atlanta to fix the noise
sway bar and rear sub frame harness
Whoever is in charge of torquing the sway bar in Casa Grande is either struggling, or the spec is just wrong.
They are towing me in today for sway bar - very loud but safe to drive?
My understanding is yes, safe to drive. I drove mine at least 300 miles with the god awful rattle.
