- Mar 7, 2020
- Naples, FL
- Model S Plaid, Odyssey
- Air DE Number
- 154
- 033M4EXG
I've been thinking about the comment about hardware differences between the P and R versions. When I talked with Zak Edson, Lucid's head of retail operations, he told me the Dream Edition was going to use special metallurgy in its rear motor that bumped its output up over the motor that was going to be used in the front and across the rest of the model lineup. However, he told me that special metallurgy only added about 15 horsepower but was more relevant to the torque.
I doubt if Lucid is doing major hardware engineering at this point. I'm wondering if they are differentiating the P and the R by using that special metallurgy motor at both ends of the P and using either the original mixed-motor configuration or the two standard motors in the R.
While a 15 hp difference more or less on either axle wouldn't equate to the 178 hp difference between the P and the R, that could probably be manipulated by software tuning. (Tesla has used software to create wider power differences than that between its versions of cars that have the same motors.) Lieberman said the P and the R will have the same torque at each of the three drive settings (670, 738, and 885 lb-ft) . . . but the P will have 1,025 lb-ft in launch control mode. Given that torque numbers get the biggest boost from the special metallurgy, I'm wondering if that's the hardware difference between the P and the R.
Pure speculation, but hey . . . it's the weekend.
