Electricians were able to install 100 amp 220v charger and set the dip switches to 80amps. It works great! I have solar producing at peak 40amps so I need to buy the other 40amps from the power company. I would like to reset the dip switches for 40amps. They are located inside the cover that does not seem to be able to come off. Is there a trick to pull the first cover that says “LUCID” off? Thank you!
