I am exploring purchase of a pre-owned Lucid. I've read that type of charging effects life and condition of battery. Is it possible to assess battery condition? Are there other factors I need to look into before purchasing a Lucid?
Some people here exclusively use DC fast chargers, which is the worst for the battery, and they haven’t experienced significantly worse degradation than the rest of us. You may be able to ask Lucid to check on the health data for the VIN, I know they are able to, but honestly not sure if they will do it for you. I wouldn’t worry about it though. Either way you will want to talk to Lucid when buying to have them change ownership on their end, give you access via the mobile app, etc.I am exploring purchase of a pre-owned Lucid. I've read that type of charging effects life and condition of battery. Is it possible to assess battery condition? Are there other factors I need to look into before purchasing a Lucid?
The current owner can login into testmycode.cc and enter his Lucid credentials. One of the metrics that will be visible is the current maximum battery charge, i.e. what is left after degradation. Mine, for example, is 105.12999765016139... down about 6% from 112kW after 25k miles and 1 3/4 years (about 15% DCFC and the rest at home).I am exploring purchase of a pre-owned Lucid. I've read that type of charging effects life and condition of battery. Is it possible to assess battery condition? Are there other factors I need to look into before purchasing a Lucid?
Is that the capacity_kwhr number? If it is, mine is very similar to yours - 105.0299976 with only 20K miles. I've reversed the charging, probably 15% at home, the rest DCFC. I guess it makes a difference.The current owner can login into testmycode.cc and enter his Lucid credentials. One of the metrics that will be visible is the current maximum battery charge, i.e. what is left after degradation. Mine, for example, is 105.12999765016139... down about 6% from 112kW after 25k miles and 1 3/4 years (about 15% DCFC and the rest at home).
Hi Bobby, I just check my battery and it is 103.67997.... I have just under 3,500 miles and the car is 5 1/2 months old. I used the CA 100% of time to charge because I have 2 free years of charging. Do you think my battery is low for the miles and time?The current owner can login into testmycode.cc and enter his Lucid credentials. One of the metrics that will be visible is the current maximum battery charge, i.e. what is left after degradation. Mine, for example, is 105.12999765016139... down about 6% from 112kW after 25k miles and 1 3/4 years (about 15% DCFC and the rest at home).
DC fast charging degrades your battery much faster.Hi Bobby, I just check my battery and it is 103.67997.... I have just under 3,500 miles and the car is 5 1/2 months old. I used the CA 100% of time to charge because I have 2 free years of charging. Do you think my battery is low for the miles and time?
Thanks, Marty
My battery is at 103 also, I rarely fast charge but the heat in Phoenix takes a toll. I would not worry, most degradation takes place early.Hi Bobby, I just check my battery and it is 103.67997.... I have just under 3,500 miles and the car is 5 1/2 months old. I used the CA 100% of time to charge because I have 2 free years of charging. Do you think my battery is low for the miles and time?
Thanks, Marty
Batteries degrade continuously, no matter what you do. It is true fast charging will degrade it somewhat faster, but by and large, your’re going to lose between 5 and 10 percent your first year, and then some smaller amount every year after. The first year is definitely the worst.I should clarify how I use the EA charger. It is 150kW charger and I charge between 50% to 80% once a week and it charges at a rate of 80 to 102kW, does this make a difference on the battery life?
Why would Lucid give 2 and 3 years of free charging if it would degrade the batteries?
Thanks for your help, Marty
It’s the heat, mine is similar. Fortunately most of the degradation occurs in the first year.I live in Phoenix, took delivery in December 2022, have just over 10,000 miles, and only instances of fast charging were during a roundtrip to Denver. My current capacity is 84.95, down 7.66%.
