How Much Range Are You Actually Getting?
  • 100% Of Estimated Range
    Votes: 8 2.9%
  • 90% Of Estimated Range
    Votes: 22 7.9%
  • 80% Of Estimated Range
    Votes: 110 39.3%
  • 70% Of Estimated Range
    Votes: 96 34.3%
  • 60% Of Estimated Range
    Votes: 31 11.1%
  • 50% Of Estimated Range
    Votes: 11 3.9%
  • 40% Of Estimated Range
    Votes: 2 0.7%
  • 30% Of Estimated Range
    Votes: 0 0.0%
  • Total voters
    280
At 12,000 miles and in the warmer weather my efficiency has recently been at or above 3.5 mi./kWh and on some 100 miles trips over 4. Most trips are short, like no more than 20 miles. No change in driving style, which is rarely above 75 mph and on 19" AS tires and no Aero blades. I got 3.6 for the first 2000 miles in Oct and Nov in New England before temperatures dropped much.
How are you all getting above 3.0 on efficiency. Are you all using aero wheel covers? I don't have those so I could understand that's my down fall.
Also Arizona is very hot 100-110 degrees currently every day.
My average since getting the car is 3.2. I routinely get 3.4-3.6 around town on 21" wheels and still having a fun drive every now and then.
I am getting an average of 3.1 here in Southern California. Nearly 14,000 miles. Mixed driving without any effort to maximize range except on the occasional road trip.
Just bout to cross the 12k threshhold. 21s. I have never seen close to 4 over anything longer than a 20-40 mile trip. I am averaging around 3.2 to 3.6. At that rate, I am maxing out at 350 miles or so on a full charge...if I manage it. 300 is closer to normal.
Have 14,500 miles on my AGT with 19 inch wheels in NJ. Accidentally reset by trip B 8000 miles ago but was averaging 3.7. Since then have averaged 3.6 including couple months of winter. Last 1200 miles were highway driving and averaged 4.0.
Have 14,500 miles on my AGT with 19 inch wheels in NJ. Accidentally reset by trip B 8000 miles ago but was averaging 3.7. Since then have averaged 3.6 including couple months of winter. Last 1200 miles were highway driving and averaged 4.0. View attachment 14252
You must live in a very flat area with temperate weather….
Live near in Short Hills, NJ. Winters usually in 20-30's and summers 80-90's. Don't have to deal with the crazy high temps in Arizona luckily.
Well there you go, only short hills no tall ones. Still great mileage.
I've been getting 3.7-3.9 mi/kWh since last December in Massachusetts. ( 5,000 overall miles)
AGT with 19's and I use the Aero covers
Mixed city and highway driving usually in the 70-75 MPH range
Similar to MKatz
I figure actual range of car is 425-450 miles the way car is driven still quite good but I tend to find chargers if needed around 20% if I'm on a long distance run .
I usually charge only once on my trips to NY either on the way there or on the way home usually just for about 20-30 min leaving plenty of range to spare otherwise home charging is painless and the way to go for 90% of my driving
I get above 3.0 in AZ, with aero covers
I'm getting 3.0 lifetime with 21s and no aero covers. 23k miles driving with no regard for range and lots of regard for fun. Lot's of acceleration and lots of miles at 75mph+.
Four thousand miles driven in my Lucid Air Touring, and achieving 4.7 miles/kWh.
Here’s the history of my range so far:
1000 miles = 4.16 miles/kWh
2000 miles = 4.46 miles/kWh
3014 miles = 4.588 miles/kWh on June 23, 2023
4000 miles = 4.700 miles/kWh on July 22, 2023
Didn’t think to take photos for recordkeeping after the first two thousand miles, but attached are the photos near/at the 3000 and 4000 miles. I’m approaching 5000 miles, so will post the result for it soon, so please stay tuned.
Wow... You must be in the coastal plains of OC somewhere. Mild temps, flat roads and not a lot of start/stops. Very impressive!
