Headlights out of alignment?
AwesoM
Richmond VA
2024 Lucid Touring
Air DE Number
0
Just found out that the headlights have a shadow/artifact by design. It’s quite annoying looks as if the lights have a bug in it hence the shadow, not sure I have ever owned a car that did that. … now that I got it out of my system …. Are the shadows suppose to be aligned with each other ? As you can see below it is not. Thoughts.
Test it against a wall or garage door on level land. Those spots are dim intentionally to avoid blinding oncoming drivers. You get used to them, and they actually work surprisingly well.
Those dim spots are the brightness allowed under current federal lighting standards. It's Lucids way of providing bright lights and meeting current regulations.
Mine are like that.
Mine were out of alignment when I got the car; both were aimed way too far downwards towards the road. I had mobile service adjust them upwards and they have been fine since. Also, the shadows were much less noticeable afterwards. Looking at your photo, you may have a similar problem, especially with your right headlight.
The lights also level off right below the side mirrors of the car in front.
Annoying when a double lane is blocked by two slow drivers. I think the brights limit the height as well, so no effective flashing to get folks to move.
Possibly dangerous when stop lights are not working. We were on an unfamiliar highway where the power was out and the traffic lights not working. Someone nearly plowed through the side of the car (intersections become stop signs when lights are out) turning onto an unseen side road. We had not seen the traffic lights and could not see them until spotting them due to the headlights of someone in front of us.
This is good to know. I will reach out to the manager for our satellite location to try to get it realigned. Did they have to take the car over night to do it? HE had suggested that he may need to do that.
Seems there are better ways to do this? Would be curious what other car manufacturer uses the same methodology.
How did you realize the lights were aimed too far downwards? I feel like mine are also, but I have no reference.
You should have zero issue seeing the road in this car. If you do, then you probably should get the lights checked.
I would like to know too. They adjusted my right one, but I feel both is too low, but no point of reference… so now I just deal with it
Service should be amendable to "I can't see the road well. Please fix the lights.". That would be my gut check in any car.
Those dark spots are shadows designed to shield the glare of the lights from oncoming traffic and the rear-viewing mirrors of the car in front of you. If those spots are showing up on the ground in front of the car, they are way too low, and need to be re-aligned. I took my car into customer service, and waited about 15 minutes while they re-aligned them. I could not believe the difference when driving at night. It's so bright, I'm surprised I don't get flashed by oncoming traffic. I guess those dark spots work!
Even at low speeds I felt like I couldn’t see far enough down the road. At highway speeds it actually felt dangerous. Also the the dark spots were clearly pointed down at the road rather than eye level of opposing traffic.
Same here. When exiting a freeway, I could barely see the off-ramp. If you have your headlights re-calibrated, and if you have DDP, I suggest you have the calibration of that checked as well. Months after I had my headlamps fixed, I had DDP checked, and it needed re-calibration, as well. I suppose it makes sense that if one somehow got skipped, the other would too.
