Gravity test drive
I think society will insist on autonomous vehicles proving they're much safer than a human driver. Our tolerance for robots accidentally killing people is probably much lower than our tolerance for humans doing so.
This is where the Waymo statistics really shine: https://waymo.com/safety/impact/
Since this is a fully driverless system, these numbers aren't cooked in the same way as Tesla's are. These are miles on city streets and highways, and normalized for drive type. Really impressive stuff. Also a long way from being available everywhere, or being available on a personal vehicle.
Yeah, I think Waymo's approach to safety and building confidence in their system is a better one. I've never tried to look into what Mercedes is doing for their autonomous driving. It'd be interesting to know how they approach data transparency.
This is probably true, tbh. We didn’t have issues with our key fob - if you look at the center console, there’s a little indent where they intend for you store the key fob while you drive. You don’t have to do that though.
If it doesn’t recognize the key fob (which it did for us maybe twice in like four months, because we had left it sitting idle for a while), the car tells you simply to shake the key fob slightly to wake it up. Sometimes I’d just hit the unlock button or the lock and unlock button.
Basically, the key fob eventually falls asleep if left idle, to save battery. Moving it or pressing any button wakes it up.
Future fob update… rechargable fob with charger built into car or apple watch style magnet at home…
No idea why they need fobs at all. Give the card for emergencies/dead phone, then use PAAK and, if you can, waak. So much easier. I’ve never used my fob for Lucid or Rivian.
I don't understand why key fobs are hard. Isn't this a solved problem, for many years now? The fob for my Toyota is quite compact, the battery lasts for years, the only circumstance it's ever failed me is from that battery wearing out, at which point the fob still has a key folded into it. I hope the Gravity is dramatically improved from the Air in this regard.
They just chose the wrong vendor.
Gravity's key system is all new, unrelated to the Air's.
I think if Tesla didn't have their somewhat ambiguous marketing that tends to oversell FSD as being autonomous driving, then you might not find so many people pushing back against it. As an ADAS system, it's pretty good. There are some concerning incidents of it misbehaving too rapidly and severely for the driver to seize control. But to be fair, those incidents seem to be very rare. As an engineer, I prefer my life-critical systems to have more of a safety-first engineering approach than Tesla has taken. But I know not everyone sees it the way I do.
Oh, in no way do I think it's ready for full autonomy. for most of my commute and road trip needs, it does a pretty good job helping me, I pay attention, but feel refresh at the end of a 6 to 8 hour drive.
-iThinkEV-
I like to drive, only want L2 otherwise. After testing Gravity, in Burlington MA, I wanted to share a couple notes.
I'm near the end of a search, having driven R1S, EQS, EX90, EV9, Lyriq, Hummer & Sierra. This is about suspension, coming from coil MS's (yup, older). Burlington had the tri-chamber air setup ($2900). I'm fearful, because, per "the internet", the single-chamber air setup is closer to perma-"Smooth", which in tri-air I found too soft, like in EV9, and EX90; a mode for long highway, or winter, but not especially composed, or damped, when changing direction. The feeling isn't like a hurtling brick, where you become keenly aware of GM's 8.5k lb, Ultium's weight, but I was conscious of 6-7k lbs floating. We were in "Smooth" most, then "Swift", a bit, then "Sprint" for a couple acceleration runs. Never highway. Honestly, think I'd leave a gravity in "Sprint" almost full time because the ride felt more accurate without being harsh.
Here in MA, Rivian's Charlestown location sends you out on some rough, urban, stuff. Like I said, I'm sort of a coils/shocks guy, but on two drives (RT and RS) I'm smitten by their air suspension. It's the only one that has me looking up air, and hydraulic, bleeding equipment, since I'm a long haul owner with a nicely fitted garage. Gravity offers way more, in each of range, charging and efficiency, but between a la carte steering wheel heat, L2'ish DDrive Prem, and having to opt for Tri-air in my case, it's another jump. Worth the added luxury? Acceleration kept grabbing/punching past what I'd guess was ~65, before a little ABS chatter back down. I won't echo other desirables. I had a similar driving experience in the Lyriq on a rotary, thinking its 6k lb might drive like a 3.6k lb Chevy Volt. Wrong. Here, don't go in thinking a Gravity will be a "minivan that drives like a car". It suits more thoroughly chilling out, where the cabin excels.
You could prepare a three column chart for all those vehicles you just drove: vehicle, pros, cons. It could be an interesting comparison. Just a suggestion!
Glad you have one In Tyson’s corner. Still waiting to see a Gravity for a test drive down in San Diego. Likely several more months at least before they have one in the studio.
Call the showroom directly. I was surprised we have two on site in Dallas and i test drove w/next day appt
So which one are you going with?
I got a call from the Studio in KOP to schedule a test drive. My wife and I will be driving the Gravity next week. I’ll post my observations.
So I probably should have posted awhile ago.
I have no excuse but we got our test drive on July 17th in West Palm Beach.
Our SA David was excellent. He drove us in the Aurora Geen with Tahoe interior to a site a block away where I switched to the drivers seat.
I should mention that we have had as our only drive a 2012 leaf, 2014 Model S 85 and are currently driving our 2018 Model S 100 with 150k miles. So not new to the EV experience.
The Gravity checked all our boxes. A really spacious and accessible frunk. A large storage area in the rear with a well with the rear seats up. Seven passenger configuration is what we want. The rearmost seats are accessible and comfortable for adults. I love that the second row has control of their own AC and the trays are just a bonus. The vehicle just has all the amenities we desire.
My wife had the same reaction as many to the Tahoe interior. She wasn’t thrilled looking at pictures but when she got in the car she changed her mind and loves it. She thinks the seats and the ride are better than the Model S.
For my drive I selected the strongest regen since I am a one peddle driver. I appreciated the roll to a stop and set the hold similar to the Model 3s I’ve rented. I was relieved that there was not a button push to start the car. I did test the autosteer and TACC on the highway and felt it was every bit as good as our Tesla. The car is easily as nimble as our Model S. And I love the modified steering wheel, whatever they call it. I played with the NAV a bit. Seemed lightning fast compared to our MS.
I only saw one other customer in the showroom on a Thursday when we were there. We ordered ours that day.
I did a test drive at NJ Short Hills studio today. The car drives excellent. I don’t own any EV yet. The acceleration pedal feels stiffer than my gas cars, you have to use some force to push down. Are all EVs the same?
Didn’t get a chance to ask many questions. Google says that acoustic laminated privacy glass can turn from transparent to opaque with the flip of a switch. Does anybody know if Gravity’s privacy glass work the same way?
EVs are all different, like gas cars. The Air has a particularly heavy accelerator in my experience owning four other EVs. You get used to it. Remember, there's 600-800 horsepower under there.
Lucid's laminated glass reduces cabin noise. It does not darken.
The Gravity accelerator is much stiffer than our Model X; this is a design choice and not specific to EVs.
Google was probably confused with Rivian which has an option for shifting glass roof from clear to opaque. Lucid is just heavily tinted.
I’m curious as to how well that whole thing works in practice. Those e-tint windows don’t really block a lot of light, they seem to just diffuse it. I don’t think it would help much with glare, in fact I think it would make it have more glare. Does it really cool things down that much?
That's the case for LCD shutter glass, but electrochromic materials can get quite dark. If you go on a Boeing 787 you'll see this firsthand: https://simpleflying.com/boeing-787-dimmable-windows/
