If you've rebooted and its still showing then I'd call Lucid Customer Care and ask them to look into it.Car parked in garage all night and still has the same error icon in the morning. How can I find out what this is for?
I have a similar exterior temperature discrepancy.Here is one, from the API.
Field 1, interior_temp: 14.800001412630081<br> Field 2, exterior_temp: 0.8000006079673767 deg c (33.4 DEG F); I drove around for an hour in Chicago area where it's 11 deg f out and the car inside on the screen never went below 26 Deg F. It's definintely 20 Deg F colder outside than the car thinks.
YesAre other still getting the “sensors blocked, dream drive limited” error regularly? That’s the only one I get every single time I drive, multiple times. Yet, DD works fine and nothing is blocked. I don’t believe it’s the condensation issue folks have mentioned as I see none. Huge win compared to the error extravaganza back in August, etc, but still odd.
Traditionally that means it has a side quest reward for youCar parked in garage all night and still has the same error icon in the morning. How can I find out what this is for?
Honestly, I'd consider contacting the most senior person you can find, and tell them to exchange the car before you force them to do it via the lemon law (I assume Florida has one). As one of the earliest owners with a problem plagued vehicle, they need to demonstrate either a commitment to figuring out what's wrong, or take it back. I know there may be no more DE's available to swap, but I personally would rather have a fully loaded GGT that works than a DE filled with gremlins.The issue is that it behaved differently in two almost identical situations. On Friday I was in the garage by myself when I raised the suspension, got out of the car, and slid under it. It remained in the highest setting until I got back in the car and lowered it using the Pilot Screen command.
Today I raised the suspension and again got out of the car, leaving no one in it. This time the suspension lowered itself without anyone giving it a command.
It may be another manifestation of how this particular car has anomalous software behavior. It's the only one of our three Gravities that doesn't geofence Homelink. It's the only one in which it takes multiple attempts to get Homelink to accept a command to operate a garage door. It's the only one that has the spinning satellite maps that show the car driving through woods and fields instead of on the road. It's the only one with the erratic Vibe lighting behavior. It's the only one that has refused certain software downloads.
Several time now I have asked both the Miami Service Center and Lucid HQ to take this car in for a thorough diagnostic of both the UI hardware and software. So far I have met with no response, and I am beginning to conclude that Lucid is not going to make any attempt to get to the bottom of its erratic behavior and instead just keep paying to have the car trucked back and forth across the state to deal with one-off situations as they arise.
Fortunately, our newest Gravity (built six months later) seems to be relatively free of such behavior, only experiencing the normal level of glitches that are being reported on this forum since the 3.3.20 update. But I have a feeling that this early Gravity is going to be source of perpetual aggravation.
I get it maybe once a week. I'm at the point where I never get the same error consistently.Are other still getting the “sensors blocked, dream drive limited” error regularly? That’s the only one I get every single time I drive, multiple times. Yet, DD works fine and nothing is blocked. I don’t believe it’s the condensation issue folks have mentioned as I see none. Huge win compared to the error extravaganza back in August, etc, but still odd.
Yep, all the greatest hits the GGT has been playing for most owners.I've finally gotten a chance to drive my Gravity more (we went out of town a few days after getting it just before Christmas). Even though I have 3.3.22, I'm getting many of the common errors often reported. Just in the last 2 days:
- Loses connectivity around town at random times, usually for <1 minute but today for 30 minutes.
- "Sensors Blocked" messages a few times a day, even when totally clean (accompanied by associated Dream Drive unavailable messages).
- Headlight error messages (maybe another phantom sensor block for auto-high beam?).
- Liftgate button has refused to lower liftgate a few times now. Gotta manually push it down when that happens.
- The climate control fan gets stuck on high sometimes, gotta turn the whole system OFF and back on to reset it.
That's in addition to all the items that were just poorly designed and need better software:
- CREEP won't stay set with drover profile. Have to change from HOLD to CREEP every single time.
- Steering wheel radio seek only changes the next song on SXM, not between favorite channels as would be logical.
- SXM doesn't remember where you left off on the screen from drive to drive. To get to your SXM favorites, you have to manually switch to MY COLLECTION, then FAVORITES every single time, which makes no sense because when people set favorites, they obviously want that to be the default.
- Autolock when leaving the car seems to be working well, but it seriously needs a confirmation chirp.
- HUD shortcomings are well-documented (tilted, won't go low enough, needs to be brighter).
- Remote climate start doesn't turn on seat heaters. Seems like an obvious thing when you want the car heated (probably the same in the summer for cooling).
- More that I'm forgetting at the moment.
Oh cool, didn't see that. Thanks.Yep, all the greatest hits the GGT has been playing for most owners.
For seat and squircle preconditioning, use the Surfaces function in the climate section in the app.
I’m also getting the “sensors blocked, dream drive limited” error periodically. Unlike some, when the error warning is on Dream Drive does not work… but 5 minutes later if the light magically goes off then it does. I’m also getting the auto high beam error alert randomly. I had clear XPEL Windshield Protection film applied when the car was delivered. Any chance this causing interference?
I don't have PPF and I get the same pretty much in every driveI’m also getting the “sensors blocked, dream drive limited” error periodically. Unlike some, when the error warning is on Dream Drive does not work… but 5 minutes later if the light magically goes off then it does. I’m also getting the auto high beam error alert randomly. I had clear XPEL Windshield Protection film applied when the car was delivered. Any chance this causing interference?
Nope.I had clear XPEL Windshield Protection film applied when the car was delivered. Any chance this causing interference?
Wait---what?
Air still does about half of those, idk how much I’d expect to change there it might just be how it is, especially creep and SXM and remote climate.I've finally gotten a chance to drive my Gravity more (we went out of town a few days after getting it just before Christmas). Even though I have 3.3.22, I'm getting many of the common errors often reported. Just in the last 2 days:
