8. Production variability = lingering bugs
New model years keep introducing revised hardware:
- New sensors
- Updated HVAC systems
- New Ethernet gateways
- New driver-assistance modules
Each requires new firmware. New firmware introduces new bugs.
Older cars and newer cars run different stacks — which makes bug fixing more complicated.
So why is the Gravity experiencing the same issues?
Because Gravity’s electronics and software stack are essentially:
Lucid Air v1.5, not a fully new generation.
It inherited:
- The same core UI and infotainment
- The same OTA infrastructure
- The same gateways
- The same ECU architecture
- The same bugs migrating to a new platform
Until Lucid launches a true Software 2.0 architecture, these issues will persist across both models.
- Why hasn’t Lucid fixed everything in 3+ years?
Because fixing deep, foundational software issues requires:
- Major architectural rewrites
- A lot of personnel
- Thousands of cars generating data
- Millions of cumulative miles
- Many OTA cycles
- Manufacturing stability
Lucid hasn’t had the scale, time, or workforce to do this at the speed needed.
The hard truth:
The Air is still having issues because:
Lucid took a “Tesla-level ambition” approach with a “startup-sized team” and “small-volume testing data.”
It’s not that they can’t fix things — it’s that they can’t fix them fast.
The problems aren’t “one bug.”
They are architectural.
