- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
I experienced a variation of this using the "Crack all your windows to ventilate your cabin" feature in the app. Each window went down a crack as advertised. Then I tried closing the windows using the same app function. 3 of the windows went up. Driver's side rear went down.
Close to my scenario. I had the rear windows lowered to take the dog for a ride and the front passenger window cracked a couple of inches to keep cabin pressure from building. When we hit the highway, I raised the rear windows and then tried to raise the front window. I saw it going down and let go of the switch, pausing the window about halfway. I thought I must have accidentally pushed the switch down instead of pulled it up. So I paid close attention when I pulled the switch up again, but the window continued all the way down. When I pulled the switch up again, the window finally went up.
The stuff that distracts you while driving with all the software glitches is worrisome from a safety standpoint. Features that are meant to operate while the car is in motion should be much more fool-proof.
