- Mar 30, 2025
- 26 Gravity GT Black, EV9
The 3.3.8 has also apparently fixed my app for vehicle offline issue as well. So whenever/if ever they put it back out, that fix appears to be in there too.
Well... the fix didn't last long. Backed out of my garage at 6:59a to start my commute to work. Upon arrival, I plugged in and headed upstairs to my office. A quick check of the app to set charge limit showed the car offline againThat's great to hear that it fixed the offline issue! I haven't driven since I updated the app yet, so hopefully tomorrow when I do, it'll be resolved for me too.
Great...Well... the fix didn't last long. Backed out of my garage at 6:59a to start my commute to work. Upon arrival, I plugged in and headed upstairs to my office. A quick check of the app to set charge limit showed the car offline againThe last time 'online' was apparently in my garage before backing out and away from my home WiFi signal.
Starting to think yesterday's fix was just a coincidence. Odd that I'd been "offline" for so long, then had a single day of daylight yesterday (vehicle being "online" and very responsive to the mobile app), only to have it revert to the offline behavior again today. Absolutely frustrating. Guess I'm headed to service anyway![]()
I checked both fobs via the app same as you, also do not have 3.3.8 same as you, and my fobs work flawlessly.Fudge!!! Fob issue again this morning. I have new iOS version but not 3.3.8 on car. Connected fob to app last night just to confirm I had last update and I did.
Since that time, I had a fob issue last night and now this morning. I walked up to car this morning, it opened, got in, and then got “key not detected” multiple times so had to start it with the key card. Fob would not start it.
Could be coincidence, but ever since I simply connected fob to app to check for update, I’ve had this same “key not detected” issue in car three times and now fob is acting like it did before the update. I guess I will try a fob battery to reset. Ugh.
Just when I thought fob issue was gone…
I am trying a fob battery reset and will see how that goes…I checked both fobs via the app same as you, also do not have 3.3.8 same as you, and my fobs work flawlessly.. Maybe you need an actual new fob battery?
In the Gravity, I think that reminder is just part of what happens when you park and open the door - no matter how you started the car…it does it to me when I start with key card.my Air keeps telling me to remember to take my key with me, but i don't use the key.
I have not seen the “key not detected” message since installing 3.3.5. I’m on 3.3.8 now and only updated the fob firmware yesterday via the mobile app but pre and post fob update, no messages about it on both versionsI am trying a fob battery reset and will see how that goes…
My experience is same as Bunnylebowski’s. My fob still works after checking its software version last might and am still on 3.3.5I checked both fobs via the app same as you, also do not have 3.3.8 same as you, and my fobs work flawlessly.. Maybe you need an actual new fob battery?
No. Are you?anyone seeing 3.3.8 again to install?
no, thats why I askedNo. Are you?
SameMy experience is same as Bunnylebowski’s. My fob still works after checking its software version last might and am still on 3.3.5
So I just had it happen again. Walked up to car, nothing. Used fob button to open, but got key not detected when I sat down. Very strange BUT I think I have one part identified.I have not seen the “key not detected” message since installing 3.3.5. I’m on 3.3.8 now and only updated the fob firmware yesterday via the mobile app but pre and post fob update, no messages about it on both versions
Weird. I'll test this tonight or tomorrow if I rememberSo I just had it happen again. Walked up to car, nothing. Used fob button to open, but got key not detected when I sat down. Very strange BUT I think I have one part identified.
Creature comfort - when this is on, since last night, 100% of the time I come back to car, nothing happens and I have to use fob button to open and get key bc are not detected. Sometimes it DOES then detect fob when I shake it, sometimes I need to use my keycard. All of this happened after app update AND making sure fob was up to date through app. Could be coincidence.
When Creature comfort isn’t on, my handles are presenting and car is starting fine about 75% of the time.
So, something’s definitely odd with creature comfort now. But car is on 3.3.5 and has been…
Tried fob/battery trick and it had no impact.
IDK.
