- Dec 25, 2021
- Atlanta, GA
- Lucid Air Grand Touring
- 83YOVHQD
Hi. Great solution. I see that the magnets have 70 pounds of force. Does that have any issues that cause the magnets to pull away from the carpet when you open or close the pieces.?Yes, just screw the magnet right through the carpet and through the plastic until it basically starts the bottom out on the metal behind the plastic. Then you are done.
Also which specific size and length screw did you use? The kit you linked to have hundreds of screws where I only need a couple. I may already have the size. Do you know the specific size you used? Thanks in advance.
