Thank you.Cabood lists GT under vehicles so believe thats what it is.
I see what you mean. Yes, bending the entire board at the connector pins is completly unacceptable, and if it doesnt brake right away, itll never hold up.
GTIs this a DE or GT vehicle?
Yikes, 518 DE and decreasing.GT
Tech told me that DE and GT have exact same part. He actually knows of a DE that was side swiped and totaled. The front end is intact. He’s going to try to scavenge it for the part.
It’s less. GM and Ford both bought DEs and tore them down.Yikes, 518 DE and decreasing.
Well, I suppose that's one way to have DE exclusivity increase. Side swiped -- I hope the driver was OKYikes, 518 DE and decreasing.
Lucid is picking my GT today to take to Chicago for repairs on the turn signal. They say they have a replacement part. Probably came off that totaled vehicleHad the mobile tech at my house today because my GT was delivered with the left front turn signal light not functioning. Same issue as above. He discussed with the factory and found out this is a known issue with the vendor who supplied the LED light board. I will attach a picture of the board and assembly. Basically the light board with 32 small LED lights on it has a four pin connector on one end. The board is mounted inside a plastic housing with a hole/port designed so the wire harness can connect to the four pin connector. Unfortunately the port is at a 45 degree angle to the board, but the pins come off straight. So in order to get the pins to line up with the connector plug they must manually BEND the board to the 45 degree angle. It is essentially a circuit board and doesn’t like to be bent. Mine broke during the bending as have others. The mobile tech tried to solder the connector pins back on to the board with four wires today, but after reassembling the entire front end, no luck. There are no available replacement LED circuit boards.
Not sure what the solution will be for this. I suspect after looking at the LED board that many of these will need to be replaced - and probably will end up in a recall situation.
On the bright side, the mobile tech was a very pleasant guy and we had a fun afternoon talking about the engineering (over) of the Lucid. He worked repairing Teslas for 10 year before joining Lucid.
And as a nice parting gift, my frunk will not open now. Tech said while he was putting the bumper back on how much a problem having two front latches for the hood has been. If one is even slightly off the other won’t work.
I wonder how many GTs have this issue...Lucid is picking my GT today to take to Chicago for repairs on the turn signal. They say they have a replacement part. Probably came off that totaled vehicle.
Hope you’re not without your car for very long!Lucid is picking my GT today to take to Chicago for repairs on the turn signal. They say they have a replacement part. Probably came off that totaled vehicle.
Thanks, I've had it for three weeks and haven't been able to drive it, so hopefully will get fixed. The tech told me the DE and GT front ends are exactly the same, same turn signal light board.Hope you’re not without your car for very long!
Intermittent warning and technician fixed it in 15 minutes. Suggest you call it in.Got a left light malfunction warning message today - it went away then came back . Almost like it was a loose wire. I understand it’s not given the comments above. Did others have this intermittent warning and then total failure.
Audi, that's who... 2300 for new light assembly. Covered under warranty. They had to remove bumper to replace.A known problem like this should not occur in newer cars. Imagine running the floor and someone tells you there is a problem connecting the harness to a key safety component and you tell them to "bend the board but don't crack it" as the fix. Do you really think the installer is not going to install the light if it cracks but seems to work? Good luck... and welcome to manufacturing Hell. Also, who designs a light that can't be serviced without removing the front half of the car?
Doing anything on an Audi requires the front half of the car removed.Audi, that's who... 2300 for new light assembly. Covered under warranty. They had to remove bumper to replace.
