- Jan 19, 2021
- None
No, Probably just a few hours depending on how hot the batteries get during final charging. Here is a chart from a member here showing the charge rate vs. time at the 150kw and 350kw fast chargers he used on the road. In both instances you can see how the charge rate slowed after 80% charge was accomplished. Naturally the level II charger at home will be slower but overnight should fill you up to 100% if the battery is capable. As some have reported even their brand new Airs will not charge to 100%. Hopefully someone with real electrical/mathematical knowledge will chime in with accurate data for you.
