I have yet to see any Air when in my Air … even when I went to see
@borski his car was having the radar work and so not there
The lucid Range / charging is not that clever yet. It shows miles added but to be honest I didn’t tend to use it.
Like you I always start with ABRP which guided me to the target charge, but being new to EV, I would tend to add about 5% more. So if it said 85%, I took it to 90%. (This was for the first stop when I knew I had to climb the pass into LA). Since it is was only supposed to be 2 stops I was fortunate to still be able to remember the two numbers
Without writing it down.
In reality a few hundred miles in
I was comfortable using the assumption 1% SOC = 1kWh. This way I was always factoring in some buffer.
so if I knew my next stop was 240 miles, and I was averaging 3.1 miles/kWh … it was simply maths to find the %SOC I needed before leaving.
so for me … I am basically doing the math while charging … I know the dest, I do a simple div 3.1 (or 3.0 if I am feeling slow or like having a giant buffer), and calculate the %SOC I need.
I tended to ignore the car display while charging - and the mileage it showed as added. Eg “Added 300-miles”
oh and I switched from RANGE to %SOC on my dashboard finding that more useful.
not sure that makes much sense - I might have to reedit this after more coffee
