Just picked up a 25 AT in November, I have had the car in to service now twice for this. When it’s cold enough (32F or less), I have noticed that a cold draft comes from the upper back part of the drivers window when driving, even when parked if it’s windy enough.
The latest diagnosis from the service center is that I should expect a cold draft from the window when it’s cold out, but that the window seal isn’t leaking, it’s simply because the window itself is cold. I could buy into this theory if the HVAC was on and blowing across the window and it cooled off, but I can turn the HVAC off and still feel the draft coming from the upper corner of the window.
I am sure others have run into this. Any quick tricks? Not sure why I am trying to solve issues with leaky window seals on a nearly $100k car.
Thanks in advance…
Thanks in advance…
