It’s fixed (temporarily) by a reboot.That's must be scary. I just got back to the US after a week overseas, I updated to 2.8.7 not haven't driven the car yet.
Does the car still drive normally, even with the screen going out (no power loss??)
Also, was this a one time thing?
The car drove as usual but no displays on the dashboard.That's must be scary. I just got back to the US after a week overseas, I updated to 2.8.7 not haven't driven the car yet.
I was initially worried that the car would stop driving. I was able to quickly find a spot to stop and put it into park and everything was fine again, I'll do a soft reset as someone here recommended and hope it won't happen again.The car drove as usual but no displays on the dashboard.
Drives normal…but you don’t know how fast you’re going! It’s happened 3 times now since the update.That's must be scary. I just got back to the US after a week overseas, I updated to 2.8.7 not haven't driven the car yet.
I encountered the same problem you described!Drives normal…but you don’t know how fast you’re going! It’s happened 3 times now since the update.
Yes. But clearly their testing suite and/or process is not complete or extensive enough yet (I imagine).It makes me wonder, does Lucid actually validate their SW updates rigorously before release?!
And you’ve released how many complex software systems?Yes. But clearly their testing suite and/or process is not complete or extensive enough yet (I imagine).
more than a few I reckonAnd you’ve released how many complex software systems?
Systems architecture complexity leads to use cases that can’t be readily identified. If you spend the time then you release software that is ancient when brand new.
more than some, fewer than others.And you’ve released how many complex software systems?
also, it rains sometimes.Systems architecture complexity leads to use cases that can’t be readily identified.
