Charging Gravity at EA chargers
jrreno
Sarasota, Florida
Tesla Model S
It is my understanding that Gravity has plug and charge enabled at both Tesla and EA chargers. Will plug and charge comprehend if one has the charging subscriptions with either of these companies , for instance a Pass+ membership with EA.
Right now it will not recognize your membership at either EA or Tesla. However, Lucid has said that they are working on that.
In the meantime, I believe that if you initiate the charge using the EA or Tesla app, then plug in, you'll get the subscriber rate.
Yes, if you do it this way, you get your membership benefits, except....I think you have to plug in first at EA, so that wouldn't work as it would start charging....
I typically initiate with the app at EA before plugging in. It works fine, no matter what the charging stall screen says when you arrive.
