I reported this issue in May, 2022: Car goes forward when in Reverse and backwards when in Drive, assuming you're on an incline and the sensors don't like what they see. Post 1337. Here's what I said back then:
Imagine that you're in an unfamiliar new car on a steep hill with busy traffic in San Francisco. You turn into a short steep driveway. Your son opens the garage door for you. You put the car in Drive and try to pull forward. Instead, the car goes backwards into oncoming, blind, downhill traffic. You hold the shift lever hard into the Drive position, you take your foot off the brake, and you push the throttle. The car goes forward a little, stops, then reverses into the traffic. OK, you get a running start, slightly scrape the bottom of the car on the abrupt angle of the driveway, and get the car into the garage. Later, you back out of the garage - and this is the fun part - the car goes backwards, stops, and then goes forward even though you are holding the lever in Reverse. At that point, the car stops and refuses to go either forward or backward while the rear end of the car is blocking downhill traffic. It takes some courage to hold the lever in Reverse, floor the accelerator, and lurch backwards into traffic, thus freeing the car from being stuck but having your wife learn some new words in the process.
Or, how about parallel parking on a San Francisco street in a parking space behind a truck with not much room. When you go to leave, you put the car in Reverse (because there's space behind you), but the car goes forward, dangerously closer to the rear of the truck. Stress level 10 as you think you're stuck. Courage required again as you hold the lever firmly in Reverse and aggressively push the accelerator. You're either going to smash into the back of the truck with all the 800+ horsepower of the Lucid Air, or, miracle of miracles, the car actually goes backwards this time - but you'd better be quick on the brakes, hard, or you'll smash the car behind you. When you extricate the car from this situation, you wonder whether this is really the car for you.
So, that's the issue I reported to Lucid Motors. Same thing happens when I try to reverse into my garage when my wife's car is already parked on the other side of the garage. The car goes forward when it's in Reverse. Spooky and dangerous.
Has this been resolved? I don't know. It hasn't recurred, and I was unable to reproduce it in my driveway, so I cancelled the tech visit last May.
