Not so far, but I will try again.Can you replicate that with the EQS?
Wonder what the issue is since I've been using a chargepoint home flex since day 1, never had an issue with charging, not even a hiccup.ChargePoint sent a replacement charger. Same problem. It is definitely on sleep or wake-up of the Lucid. I will open another case with them. I have had a successful charged, only to have the car unlock, I have to do that to remove the plug, and initiate a synch and subsequent red light. Charger clicks, likely after determining the type of car it is charging.
Are you using the ChargePoint Flex to charge at a certain time or is it set to initiate charging immediately?Wonder what the issue is since I've been using a chargepoint home flex since day 1, never had an issue with charging, not even a hiccup.
10 pm to 8amAre you using the ChargePoint Flex to charge at a certain time or is it set to initiate charging immediately?
