- May 7, 2025
- Model X, MachE-GTP
I know that with Teslas the BMS will do cell balancing at the top of the charging process... between about 92% and 100% IIRC. So it's often suggested to charge to 100% occasionally and immediately drive it so it doesn't sit at the high SOC. Subsequently running it down to single-digit SOC helps the BMS to calibrate the present capacity.
Is that also true for Lucid?
