- Nov 19, 2021
- Cupertino, CA
- Air DE-P, Gravity DE
- Air DE Number
- 241
- Gravity DE Number
- 013
- Q1BTN5Y3
Ahhhhh. You don’t have to move it in small circles; you can just hold it there. Moving it in small circles is just because there is no symbol or anything of where exactly to put it, so if it isn’t working you can “search for the spot” so to speak.You can just hold the card against the pillar. I already had to do this after 2 months.
With a dead fob you have to do the following, according to the manual: "Depleted Key Fob Battery.....It is still possible to access the car even if the key fob battery is depleted. Press the driver’s side door handle momentarilyand locate the camera on the B Pillar. Place the key fob on the B Pillar under the camera, and while still holding it,move the key fob in small circles."
But it isn’t a requirement for it to work. It works the same way as the card, just in a different spot.
