Air GT Driving Impressions (both 19” and 21” wheels)
Let's be realistic here. I'm 6'2" 240lbs and have to watch my head each time getting in. My wife is 5'2" and she has to do the same. Once in the car, however, you will have plenty of head and leg room.
You will need to find an entry and exit technique that will not pinch a c-spine nerve. You will work it out because you will WANT to drive the car that much!! :)
I get you. I totally had to adjust how I did it, but the nice thing is I didn't find it hard to get used to even on a few drives. Will see how I adjust for daily use after I pick it up on Friday.
I’ve have/had 3 MB SL550’s so getting in and out of a Lucid should be no problem in my case….
I have spinal stenosis and an arthritic left hip. What I do, and I tried out a Lucid Air in the Scottsdale Design Studio, is I plop down sideways on the seat cushion, then lift my legs and rotate into the sitting position. It works for me on my DD and it worked fine for me on the time I tried the Lucid. But I am 5'7" 145 pounds so I don't know how that would work for a larger individual.
I'm 6'2" and adopted that same entry technique when the old 'one leg in, sit, bend neck, followed by other leg in' approach pinched a c-spine nerve in my neck. That was getting into my old Lexus LS460.
Once I changed to the sit first, then rotate legs technique, the nerve pressure was eliminated and my head bend is forward getting in (a more natural cervical pivot), rather than sideways (much less latitude).
Pain should not be part of the driving experience!
There are actually car seat swivel cushions on Amazon. I have never tried one but who knows….
Just got back from a test drive.
One thing that really impressed me was the suspension. I don’t know how they managed to get cool springs to feel like air suspension. It’s smooth on the straights, covers up road imperfections well but then doesn’t have body roll in corners. Quite impressive how they did that.
This was with the 19s
Couldn't agree more with you!! Well said. At 6'4", 290 with athletic knees and a low ride I anticipate my ingress/egress technique will need to be modified. Who knows, this might be the incentive I need to lose weight! I had assumed if it was problematic I could replace it with the Gravity when it comes out....but with the pictures I've seen of the Gravity I'll take the sleekness of the Air and a diet.
Motivation toward more fitness is always a good thing. I suspect once you get in, situate yourself (which should work), and then drive, you will want to make any accommodations necessary to get back in and drive some more!
or be like me and say..."oh this has more room and is comfortable for my fat gut, guess I don't need to lose weight afterall and I just had the wrong car..."
Had my car for two days now. Getting familiar with the controls and regenerative braking.
Question: There is a definite high pitched whine when pressing on the accelerator. Disappears when I take my foot off and reappears when I press it again. Is this normal, and how do I get rid of it
If it’s what I’m thinking of, I was told by the SA that it was the artificial engine noise or “acceleration sound” as he called it. He said it could be turned off in the settings.
I would be surprised if that whine can’t be muted. I didn’t try.
Some of this sound is needed for pedestrians, particularly the visually impaired at intersections.
He's wrong, at least right now, and as far as I remember, Lucid didn't pump artificial sound into the cabin. So that whine you hear are the motors doing their work!
There is the low speed pedestrian alert tone which emits at 17mph and under, and then the electric motor sound. There is no artificial sound pumped into the cabin :)
Edit: I also happen to love that motor sound. The auditory feedback is nice to have.
I test drove the AGT for a bit over an hour today in Millbrae and was fortunate enough to get both the 19” and 21” wheels to test as they had a pair of GT’s on site. Both cars were on software 1.0.8 and were late-run pre-production. The 21” car was white on Santa Cruz and the 19” was black on Santa Cruz.
  • General Impressions
    • Interior
      • We’ve had a lot of talk around the Santa Cruz vs. Tahoe interior; I‘d say the Santa Cruz looks quite good in person and is my preference over the Tahoe. The contrast stitching, walnut and overall color palette are very tasteful and well integrated. The Tahoe looks good, for sure, but feels much more monochromatic and doesn’t feel as special inside.
      • The steering wheel in some pre-production cars does not extend out as far as on full production. The black AGT had the wheel go out further than the white one. I was assured this was due to testing out different parts for the steering column and full production cars will have a longer extension (it does not make much difference ergonomically)
      • It took me a bit to get used to the seats again. There’s a lot of adjustment range that you might not use at first - take your time adjusting when you hop in the first time. Lumbar, thigh support, bolsters - it all makes a difference.
      • The headrest moves forward/backward electronically and has a nice range to it.
      • Massage is fantastic. ’nuff said.
      • The black car was outside on a sunny day all morning and had negligible heat gain. I expect darker cars won’t have much issue during the summer (unless you’re in a truly hot climate)
      • I specifically timed my test drive to make sure the sun would be coming over the visors and not far enough overhead to be blocked by my eyebrows so I could see how eye-stabby the light is. I am that big of a nerd. I’m ok with the fixed roof and it seems better than the Model S by a fair margin (I haven’t verified the actual tint levels between the two). I intend to tint it if the sun becomes bothersome, but it was not a deal breaker. If you’re light sensitive like I, you’ll probably be ok.
      • I didn’t have any issue with the cellphone charger at all (iphone 12 pro). I’d note that the fit is pretty tight so adding a case might make it more of an annoyance.
      • I was disappointed that the mirrors don’t move down when you reverse. That strikes me as a big omission, even with the cameras available, but this should be fixable in software.
      • Pro tip: if you want your seat coolers to be really cool, have your climate control blowing air into the footwell as well as directly. The means the coolers grab the cool air coming out from under the seats - the difference is quite noticeable on a warm day.
    • Exterior
      • The white just looks freaking awesome. Black is nicely metallic and also is quite elegant. Both colors are slam dunks.
      • I’m absolutely going to wrap the car, at least the front if not the whole thing. The paint is special and really warrants this extra effort imho.
      • The trim is a nicely matte texture that sets off the paint well. Both cars had some mileage on them and there weren’t any scuffs or dings that drew my eye. I did note that one piece of the matte trim above the right headlight had come away from the body - apparently this was someone‘s fault during service, not necessarily a defect or bad manufacturing.
    • Throttle & Brakes
      • Modulation of the pedals has continued to amaze me. In all three driving modes I never felt the car be too snappy or reactive, nor was it sluggish. Frankly, it is the best I’ve used to this day on most any car.
      • The throttle never fatigues me in my (admittedly brief) drives. It seems to have the right balance between resistance and give so that you don’t wind up suspending your leg and activating muscles to keep it in place. I spent about 15min in stop-and-go traffic on the 101 and never felt a moment of over-activation in my leg in order to maintain a sedate pace, and the same when cruising at 75mph.
      • I also continue to be surprised by just how usable the other drive modes are. The aforementioned traffic was in sprint (edit: originally said swift) mode - I never felt the need to switch out. You could dawdle around town just fine with 800bhp on tap and never once feel it was too much.
      • Want to go? Just give it the beans and you rocket off. Acceleration is excellent in any mode and I never felt like it was a big step back from other cars (will compare with the DE below).
      • The brakes on the AGT were better than I remembered and just hauled me down from speed, no problem. High and Standard regen were just fine, and the brakes blend very well with it - almost seamlessly. The pedal is definitely more responsive than the Model S by a long shot.
      • In traffic I was glad how easy it was to maintain pace without kicking in the regen, even in high. You get so used to maintaining your pace that if you completely let off the pedal the regen kicks in a sudden way. This isn’t a drawback actually - I was happy how relaxing maintaining pace in stopped traffic was, even if the full regen could be sudden.
    • Handling
      • I continue to be surprised by how well the Air can manage its mass. Most electrics (except the Taycan) have a very hard time hiding the weight they carry, but the Air does an excellent job of managing it. The Taycan is the leader for sure here, but damn the Air is close.
      • The distinction here is you definitely know this car is heavy! But it doesn’t really affect you in the way you’d expect, letting you be more confident in your moves.
      • One thing was handling some really big pedestrian-crossing-humps. Right by the Meta office in Burlingame (over by the bay shore) there are some very large humps for the pedestrian crossing. It took that without getting unsettled.
      • The one drawback is if you punch it too early in a turn the traction control will cut in to keep you from eating the wall, which can be off putting if you’re not really pushing it. It’ll take getting used to the mass low-down and how to manage blending in the throttle as you turn - don’t trail brake, and definitely modulate your throttle until you have a clear exit.
      • Another note is how much detail comes through the chassis and steering wheel on the Air, regardless of wheels. You get an immediate sense of where the wheels are without much effort and can easily place the nose of the car in a turn. Potholes and other toughness doesn’t intrude on you however and fatigue isn’t that much of an issue. If you’ve ever driven a Porsche GT3 RS you’ll know what I mean.
  • Comparison with the DE-P
    • Power
      • My main concern was the AGT would feel underwhelming in comparison to the DE. I’m happy to say this is not the case!
      • In all three modes the AGT will leap forward without hesitation. That hammer blow on the DE is stunning for sure, but I doubt anyone with the GT will miss it.
      • At one point I had to squeeze into a gap between a car and a truck loaded with gravel - I punched it once I merged away to keep from taking a rock to the windscreen and easily rocketed past in smooth mode to…speeds.
      • The mid-range punch is definitely less than the DE but not to a meaningful degree. If you need to pass someone in a hurry you’re golden.
    • Handling
      • I didn’t expect much difference here but it is there. The DE has so much power that if anything it is just a bit harder to calibrate your throttle/brake when you’re pushing hard. The car is so reponsive, so fast, that you’re more on the edge than the GT at almost every moment.
      • The end result is the DE can take more getting used to before you can take full advantage of it. The AGT is much easier to get in and feel like a hero.
  • Wheels - 19” vs. 21”
    • This has been a big question for a lot of us. I’m happy to say - 19” all the way and you won’t regret it, unless you really really really want the looks.
    • Imagine an AGT on 21” wheels having the volume for driver feedback dialed up to 10. You’re getting the maximum input and not missing any available details.
    • On most cars like this, stepping down 1-2” in wheel size would result in the volume going down to 3 or 4. It would feel muted and distant; you’d struggle to capture the details and read the road in the same way.
    • The AGT on 19” wheels and tires was a delight as despite the amount of sidewall, you don’t lose much detail. Image volume at 7 or 8. It is down a few notches, but not so far that you’re straining to hear. Everything still comes through.
    • If anything, I found the 19” wheels to be less fatiguing and more enjoyable simply because it let me process what was going on more readily instead of being overloaded. It also was a vastly better general driving experience.
    • That aside, the 21” wheels look So. Damn. Good. Oh well, maybe one day.
Edit: Added this later
What I didn’t get to test & caveats
  • Today I did not get much time to mess with the sat nav. Some owners have had issues, and both cars were on out-of-date software (1.0.8 when cars are now on 1.1.6+). The automated driver assist wasn’t active, so I can’t tell what the car is like when trying to knock down the miles with cruise control.
    Apple CarPlay isn’t active yet in the satnav. Also, the stereo was not the production version (no subwoofer) so I didn’t test it out.
  • I haven’t done a drive longer than an hour or in bad weather. Wet roads are still an unknown to me, but from reviews of the car elsewhere it seems to handle it well. This is one reason I’m sticking with the 19” wheels on all-season tires.
  • Luggage space looks fantastic, but I haven’t tried to stuff it full of bags yet. Once I get mine home I’ll post my impressions.
  • My drives of the competition have been about the same length, but I’ve never lived with an electric car. Other people in DC may have a better idea of some benefits and drawbacks of competitors that I don’t.
Final thoughts vs. the competition
  • I’ve now driven the Taycan, EQS, Plaid, S Long Range and the Air Dream and GT. My original impression that the Air is the right balance continues.
    I was most disappointed in the EQS after a few drives over it being just ungainly in handling and overdone on the inside. The Air manages to feel much more elegant even if the material quality is a bit lower, but not by much.
  • The Taycan is absolutely the better driver’s car, but not by enough to matter in my opinion when you take into account the range, storage space and interior room. If you go from a Taycan to an Air you’ll be surprised but just how much nicer it is to live with, and you give up very little in terms of performance for a comparable trim (GT vs. Turbo for example) and will save money with Lucid as well.
  • I despise the Plaid’s brakes (I have not tried the carbon ceramic yet) and both the Plaid and LR to me are far less nice to live with. Tesla makes up for a lot with the Supercharger network and the software, but I can’t get over the quality issues I’ve seen lots of people have for a $140k car. The Air suspension is also vastly more composed and still manages to communicate the road surface extremely well, even on the 19” wheels.
This is all my first read after the drive today. After I sleep on it I’ll have some more, I’m sure. Some things I didn’t get to do were (a) mess around with the Nav a lot, (b) test the stereo since this one didn’t have the full production version, and (c) take it up some backroads. All that aside, I’m certain now that I’ll take delivery and I’m more excited than ever for the car.
Fire away with questions and I’ll do my best to answer. Here’s some photos as well for you all:
Special thanks to Jessop and Bryce at the Millbrae studio today - they made it a very good experience.
Apologies I’m advance if I missed it but did you try the auto cruise control? If so, how well did it do? My BMW’s auto CC is kinda first gen generic but works. How was the “auto-pilot?” Any good?
I’ve had the car since early May. So far ACC is smooth and maintains distance very well. It still lacks lane keeping but I believe that will be added later this summer. Overall I consider it better at what it does (accelerate/regen/brake/distance) than most systems, but the missing features (lane keeping, etc.) are a drawback.
That is very disappointing. My $30k Leaf can do all of that including lane keeping and Has been able to for the past 4 years. Perhaps when I finally get the car, they will have this together. It would be fine if I had received the car in Feb/Mar as promised. However, since they have delayed my delivery for an extra 4-6 months, I will be much less tolerant of deficiencies that the extra time should have solved.
