Software 3.6.5 Released
Doesn't necessarily look like an app issue to me. If you think about the command flow, the app requests a Vent or Close action, that request goes through Lucid's backend to the vehicle, and the Gravity then has to interpret the command and execute it through the individual window controllers.
In this case, the vehicle clearly receives and acts on the command — three windows close correctly, while the fourth window instead moves farther down to about halfway. That would seem to point more toward how the command is being interpreted or executed on the vehicle side (or by the individual window-control module) than simply an app problem.
That’s a window regulator issue and it will get fixed. In time. I’ve had several changed.
3.6.4 here with no update yet… I’m going to get 3.6.5, right?
…right? 👀
@marqie , could you clarify whether the window behavior demonstrated in the video above is one of the issues addressed by 3.6.5?
Specifically, when using Vent from the Lucid app, all four windows lower as expected, but when sending the command to close them, three windows close while one instead lowers farther to approximately halfway.
A few owners on this forum have reported similar behavior on 3.6.4, so it would be helpful to know whether this is among the window-related issues targeted by 3.6.5. Thanks
I had that issue less than 60 days into ownership last year. It’s not solely due to 3.6.4. I mean, it may be for some, but it’s been around for a while. Mine was fixed with hardware…
Also, I think that’s really a question for the swfeedback email but just my opinion.
swfeeback never replied to any of my emails/requests so far and I've sent them quite a few
Installed 3.6.5 a few hours ago and so far my window issues have completely gone away. While that may sound like resounding success, I will give it a week or so before passing along a final verdict.
My experience with my Gravity's windows prior to 3.6.5:
1) All windows have been affected at some point
2) No windows had issues until a few weeks after delivery (6/30/26); began with front driver window--maybe due to it initially being the most frequently used window(?).
3) Windows that were commanded to fully close would arbitrarily stop and retreat a fixed distance (roughly a third of the window height), as though it sensed an obstruction. In order to close a window, I could either try repeatedly commanding it to fully close or just inch it up in small increments.
4) Prior to 3.6.5 the behavior listed in point 3 would occur at least daily with at least 1 window.
The car is going into service next Monday for a 'long range radar calibration' so I'll have an opportunity to inquire about the windows if this fix does not bring 100% intended behavior.
Fingers crossed.
While it hasn't been a week yet, my window issues would've presented themselves a handful (or more) times over 72 hours on 3.6.4.
So far, not a single unintended behavior from the windows on 3.6.5. I'll continue to monitor it and report any issues.
It appears 3.6.5 is more about correcting/working around unexpected pinch protection activation than the issue I shared, which is more about intermittent up/down command confusion. I have had other windows intermittently go down when commanded to go up from the driver’s door window switches while operating the vehicle.
Regarding the app vent feature, I should further add that the driver's window does eventually close with 2 more close commands, but only after first going down (almost fully) again. I have experienced this afflicting other windows too. So that's a tally of one command to vent, and something like 3 commands to close.
Again, probably not the issue 3.6.5 is addressing but it looks like there are some remaining issues under the broader window closure umbrella topic that we can only assume are on the service/update radar.
I do hope the update lands on your vehicle soon to (fingers crossed) resolve your command confusion issues.
I can confirm that I’ve only experienced the ‘mis-interpreted pinch’ and as a result windows refusing to fully close via the app and switch controls.
I have had the window issue one time on the rear driver side second row. It took several attempts to close the window. I did not report it and being honest I rarely roll my windows down so it doesn't seem like a problem to me. I find it curious that the roll out seems to have paused. Is it because it is limited to owners who have filed a report or is it because it is not as solid as Lucid wants it to be. As an owner I would love to understand what is going on but my Gravity GT really has been pretty solid and my service access experience is amazingly poor. No one calls back, the recall notice has been ignored by my local service center and the excuse of being busy is not acceptable. I called when the recall went out and have made several calls. No one ever calls back. This is why I simply gave up on even trying to go there. I do have an appointment in a month but I had to make it at the end of July for November, Still it's a great car and I hope that the service centers find a way to become better. I am rooting for Lucid.
It is not paused; it is simply only for some vehicles. People apparently want updates that don’t apply to them. :)
Which center?
My Gravity has experienced all the crazy window behaviors mentioned here. I really hope my car is on the list to receive the 3.6.5 update soon!
..Mine too
@marqie, is there a way to tell if your vehicle has the HW config that will get the update?
Which center?
Costa Mesa California
