LucidLogger
You didn't provide the logfile of the database and it looks like this is the problem.
I don't know how fast your Qnap is, but I saw some cheap Synology need 30 minutes to init the database.
try to start from scratch.
> docker compose down
delete the content of the folder mysql. NOT the folder itself!!!
> docker compose up -d
And wait! Be patient - it may take one hour if your NAS is very slow!
You have to wait untill you can read this in your mariadb container logs:
/usr/local/bin/docker-entrypoint.sh: running /docker-entrypoint-initdb.d/sqlschema.sql
if that doesn't work, please send me the log of the database
An hour to initialize a local database? Mind if I ask why that would be?
I'm going to take a look at the repo if there is one, but that seems outrageous.
ok. I did as instructed and I have the same issue. Still errors with mysql and then with the JSON error with the My tesla / my lucid button.
attaching the log from the ip:8888/admin page
converted to pdf.
also added the files that are in the mysql folder
  • logfile2.pdf
    logfile2.pdf
> docker compose down
I had a NUC lying around and installed ubuntu, docker and then your proedure and everything up and running in 15 minutes. I do not know why the qnap container station is causing issues. I will investigate and if I find the solution I will let you know for future QNAP users. You should see me on your backend now.
CaptK
