Gravity Bugs / Issues
But if my iPhone GPS is a bigger issue, would need to figure another work around. I am NOT attaching my iPhone to the roof or side view mirror once CarPlay comes out just to receive a gps signal! 🤣
When using carplay, your phone will get GPS location from the car so it will not be a problem.
Let me bring some positivity here haha
I was walking around my garage with the key fob on me and noticed Lucid handles this scenario by temp disabling auto unlock/lock. Good job!
My toll tag DID work today but I put it right where it’s supposed to go - which is only big enough for a toll pass.
I have an RFID “tag master” for work. Can’t get it to work anywhere on windshield. Just have to wave it outside of the car…all good.
I still haven't gotten my tolltag to work...it's a newer type of sticker that's about the size of a stick of gum (rather than the previous credit card sized ones). I have it mounted vertically next to the radar detector. I'm concerned that the tag's antenna is designed to be used in a horizontal orientation. The tag is entirely within the cutout but still seems to not get read when I go through the booth.
Is the “Animated” button under Lucid Vibes supposed to do anything on a non-tech package GGT? Mine does not impact the ambient lights in any way, so I figured it’s vestigial and left in UI from Tech package as the manual says something about “in equipped vehicles…”
I think it’s buggy. Every now and then I will see the lights dimming / flashing but it’s not consistent. I still have no idea why they don’t just leave the one along the dash / windshield on while driving either.
My key fob also stopped working. I’ll be getting the replacement next week. According to the service advisor they have a new revision of key fob.
I’m also still having issues with the key card. Most of the time tapping on the NFC pad results in a “Tap on Console to Drive” message. Sometimes it works a few seconds later, but sometimes I have to either reset the infotainment or, I have found that it will start to work if I slide the inner console all the way forward.
Interesting re: new fob…wonder how quickly they can get those distributed or if they will just wait for folks to complain. Also surprising as the gov manufacturer is well known and has done a ton of fobs for high end cars - so hard to believe the actual fob was the issue. But who knows…
Someone else mentioned it took a long time, and a trip to SC, to program a new fob, so Lucid may just wait for complaints if, in fact, they have a fix.
A revision could simply mean a firmware update to the fob itself, not necessarily hardware
I just talked to my SA within in the past 30 min and he told me there is a new updated key fob. Whether it is updated hardware or the same hardware with updated software/code really doesn't make a difference. If it is more reliable....hallelujah!!!
That sounds like it might be the console wiring issue, which would definitely make it a Service item.
My guess is that’s where all the fob issues stem from. That would certainly explain why it might not have shown up in testing as readily, and how they possibly could not have caught it before production.
If they knew the fob had issues, there’s no way they wouldn’t have held back launch.
So my guess is once they do the eventual (or maybe already existent) TSC to inspect/fix the wiring in the center console to the security node… no more fob issues.
This doesn't seem to do anything meaningful on my DE. I think this is in the Jira backlog...
Are the Blind Spot cameras really so low resolution or are mine super blurry/out of focus? Almost look like 480p resolution...
Hard to say at this early stage. In the early days, the Air ones were pretty bad also but became clearer over time. I'm guessing it's software related and will hopefully evolve over time where the image becomes a little more clearer.
Yeah they looked mediocre like that on Gravity test drive, the Airs are far superior, hopefully it’s just a software update that will take care of it.
I have not noticed the resolution on my GDE. I'm more interested in speed and reliability with these cameras because of the obvious urgency of getting the video to my dashboard.
Yeah that's why I didn't really pay attention at first - reliability and speed is definitely more important.
But as a video codec engineer.... just basic 1080P 60fps should be a cake walk in this day and age.
If everyone else's looks like this then I'm not too concerned it being a HW issue with my car.
Mine are good enough for what I need them for. I’d be upset if I were trying to watch a show in 4K, but I’m not. If they get better, great. If not, I am okay. I’d rather my fob work… 😏
New bug for me and would like to know if others have it…
When my iPhone is charging wirelessly and I am using Waze (I use an AirPod to listen to directions), I very quickly receive a “no GPS signal” screen warning on my phone from Waze and it shows my car driving off somewhere else and keeps trying to re-route me.
Pick up the phone and put it in my lap, warning goes away and Waze updates location correctly and works.
Put it back on pad, get the error message.
Tried 3-4 times, same issue. Haven’t tried other apps.
The center console is like a Ouija board. Maybe no one needs a new center console, just an exorcism…
Again, not at all a huge deal, but curious (to me)…
