Charging notifications incessant
pyle112
Referral code M7633PFL
Lucid touring
M7633PFL
Anyone else have this issue recently? Got the new aOS app last week and after charging last night I get a notification while plugged in that charging is complete, almost every 10-15 min.
You can turn that off in the app. I agree, it’s pretty silly that it works the way it does. It would be nice if they gated it so that it doesn’t report anything g less than a kilowatt to clean that up.
Tagging @marqie for awareness. Hope this gets resolved in future updates and communications around resolutions are made in detailed fashion. I personally am shutting off notifications (as it seems others have) but one day would like to turn notifications back on to have a full featured lucid experience.
It happens when:
1) charging finishes,
2) you wake up the car, and it tops up (no matter how small), and,
3) if you have scheduled charging set, so the car wakes up to charge, but is already full.
The most likely culprit is you waking up the car with the fob or mobile key. If you turn off passive unlock, does the issue go away? (I know it’s a workaround; it would just help identify if this is a real bug or actually the wake up issue)
It happens when:
My passive unlock is off. Haven't done anything new since last charge except updated the app on aOS.
Weird! And you're not opening the app regularly to check it? (which would wake it up and trigger a "charging completed" notification a minute or so later)
If so, then I have no idea why that might be happening and it sounds like a bug!
Nope not opening app. Might also be related to vehicle getting warm running whatever cycle it was attempting (per the other thread)
Looks like a new version of the app was pushed today. I'll see overnight what the situation is on the annoying alerts.
I am excited to see some of these annoyances fixed.
They are small petty issues but their are a bunch of em.
Was just coming over to talk through this. It does this repeatedly overnight--it is weird.
The Android app issue that caused this was resolved in the last app update
