Inconsistent regen?
L-Dude
(Your highness)
2025 Air Grand Touring
I am brand new to my '25 AGT and I am trying to sort things out. One of the features I'm trying to understand is how regen in applied in each of the three drive modes. There are times when standard regen is unavailable in any mode except Sprint. While driving yesterday, I could only get no regen, or full regen. Even when regen was set to standard, I was getting full one-pedal driving, with no need to touch the brake at all--even when coming to a stop. Today, standard regen appeared in all modes--for a while. Then it would disappear for a time and then return. Full and No regen are always available in every drive mode.
Any idea what might be going on?
Wait, you mean those settings are actually disappearing from the pilot panel? I basically never change those so I'm not sure if it's changed in a recent update, but that sounds very weird. Haven't heard anything like that before.
No the buttons appear normally, but getting Standard regen in any drive mode is hit or miss.
So, can someone point me in the direction of a detailed description about how the different drove modes and regen settings work?
Have you checked your owners manual? I have found plenty of good info there on standard features in the past.
Does it have any connection to your SOC?
I'm sure it is in the manual somewhere, but IMO the manual has soooooooo many warnings and disclaimers interspersed with its explanations that it is a very arduous read. The info I find here is much more concise and helpful.
Regen can change based on battery level, temp, or drive mode. It’s normal for standard regen to come and go—especially when the battery’s full or cold.
FWIW, my interest in drive mode settings came as the result of a surprising (and thrilling!) four wheeled power drift across two lanes as I accelerated briskly into traffic while in sprint mode. :oops:
In case you don't already know this, if you are close to 100% charged, it will often disable regen. This can come as a bit of a surprise if you are used to one pedal driving.
My whole experience with regen/drive mode has been with the SOC between 50% and 80%.
I've been pouring through the manual and this stuff is anything but straightforward. That's not a criticism, just an observation.
