Gravity Test Drive writeup
JoshG
SF Bay Area
Air-T,i4,R8,NSX-T,DMC12
Valley Fair, San Jose
10/24/25
Process:
I was the first drive of the day, so after signing in and DL check in the showroom, they took me down to the underground parking where the lucid rep (Anthony) drove the vehicle out of the garage and up to the street where he pulled over to let me drive. Every other test drive of the day will be different - you will meet the car coming back from previous test drive out on the street... last guy/girl gets out, frunk gets popped so they can hand you the gift bag from the supply they keep up there, then new driver waiting there at the curb can jump in. The rep who was with you on your drive stays and takes next person, the rep who escorted last person out to curb now escorts you back to showroom where you can then spend more time exploring the showroom car, including playing with the full UI, checking out seat folding, storage things, whatever you want.​
All drives are scheduled for 20 minutes and a roughly-planned-out (but not strict) route that includes highway and city streets. Mine was the first of the day, and I was there early and they were ready early, so we left at 9:50am (10am reservation) and I got 30 minutes instead of the strict 20 minute drives after mine. They were VERY insistent we must be back at 10:20am for the next driver lest the whole day start getting backed up.​
Route:
For those that know the area, we left Valley Fair on Stevens Creek towards Winchester, left on Winchester, right onto Hwy 280N. Then only allowed travel on 280 for one exit to Saratoga Ave., turn right, right again on Stevens Creek, back to Winchester, left on Winchester, and then to back area of mall to the disused bus stop area that Lucid now has marked off for the test drive day, where switchover to next driver/family takes place.​
General Impressions:
I don't think I'll give any insight that hasn't been better described by some of the great youtube reviews and industry reviewers, but I wanted specifically to compare it to how my Air Touring drove, and I'd say overall driving feel and comfort, road holding, etc., it does feel AT LEAST as good in almost every way to the Air. Very taught, nicely dampened road feel but still feels connected via wheel and butt to the road.​
The only case I can find where it may give up a little bit of dynamics to the Air is a silly case you'd likely never encounter in normal driving... a back-and-forth twisting of the wheel to deliberately kinda bounce the vehicle left and right... like if you were trying to make your passengers sick or spill their drink on their lap. Unless you're autocrossing or doing some slalom type course, you'd not really do this in any case I can think of. BUT I could feel the Gravity being a little taller with a little more sway left-and-right when doing this. Not sure if it's how the suspension is designed, if it is due to the 4WS/DHP, or just due to higher center of gravity, but it sways a little more if you really attempt to get it to sway. Didn't concern me at all, just an observation.​
In normal high-speed turns, (hwy entrance ramps, normal turns, lane changes...) it felt as good or better than my Air. Then again, this car had the big wheels and my air has the 19" range wheels, so the larger wheels, lower aspect ratio rubber, specific tire compound difference, etc. probably should make the gravity feel tighter, and I think in most cases, those things probably offset the higher CoG in the gravity to give it slightly better handling feel. If you're coming from a GT with larger wheels or an AirDE-P, then you might find the Gravity as good, or maybe just slightly not quite as good, but I can't speak to that. But I walked away super impressed with the handling on the Gravity.​
Extra #1:
Since I had about 10 extra minutes, I went into the big parking area near Saratoga & Stevens Creek to try turning radius checks and some auto-park testing. The former went great... very surprising how tight you can turn it around... did several 360 loops... definitely felt tighter than my Air touring, clearly due to the Dynamic Handling (4WS) option. The latter (auto-park tests, both parallel and perpendicular tests between parked cars nearby and on nearby streets) didn't go well... or I should say it worked every bit as good as it does on the Air. I tried it 5 times, on what seemed to be perfect/easy test cases, plenty of room, both parallel and perpendicular, and we enabled parking search mode, drove SUPER slowly past the perfect test spots, went quite a bit past the spot waiting for the chime and indication it found the spot... and... nothing. The Lucid guy (also an Air owner) was sure he could make it work, but he couldn't either. We suspect software improvements to come will fix it?​
Extra #2:
We still had a few minutes, so he let me try launch mode at a stoplight since there was almost no one around on the streets behind the mall. Got a full 0-65 sprint with launch mode and it was great. For me, used to Air Touring launch mode, I think I expected it to feel like it pulled even stronger than my car due to much more horsepower, but offset by greater weight and slightly higher center of gravity, and if it is faster it didn't feel like it was by very much. For ICE drivers and maybe Air Pure drivers, it will feel breathtaking, but if you're used to Tesla 3-Performance/S-Plaid or Air T/GT/DE, you won't be blown away, but for a full size "SUV", it's damn impressive.​
Recommendations:
  1. Plan for, or hope for, little highway traffic at. your drive time if you can. There was very little traffic this time of the day in this area, so we were very lucky. If you can plan your time to avoid rush hour, obviously try to do that. If 280 had had a lot of traffic, it would have been a bummer of test drive. We were lucky... no one behind me on entrance ramps and fast-moving light traffic on highway, so i literally stopped right at start of very long entrance ramp to let traffic ahead merge on, then did full blast acceleration onto highway, merging in at 70mph.
  2. get there early for your test drive, and if possible, get to the waiting area early. So if you can get in the car ahead of your appointment if last guy returns a little early, you will get more time which you should take on some sidestreets or parking lots to get a feel for turning radius, parking ease, etc. Ask to use the full time you can get... but know they focus on return time for the next person at the :00, :20, :40 after hour rather than the length of your drive. Leave early = longer drive if you ask for it.
  3. Don't spend ANY of your test drive time exploring the screens or UI, the frunk, folding rear sets (unless you have passengers with you), etc. Do the very basics (seats and mirrors) and then get going and really explore the driving. Any time you spend trying out immersive spa mode or whatever, or trying Tidal sound, or exploring rear seat access or frunk storage, or Carplay, or whatever, you will not get back for your driving time. If your setup is like the San Jose setup, you can do all this back in the showroom where they have a production Gravity there that is fully explorable... try all those things with no time limit in the showroom. The mall and the Lucid showroom were nearly empty midweek morning like my time, so there was no time pressure and I spent probably 30-40 minutes in the showroom car checking out all the menus and interface stuff, really exploring seat movement, storage, etc.
(crap, missed edit time-out... i meant "taut", not "taught"!)
Excellent writeup, thank you! Great tips for my test drive.
I'd booked that 10am time slot as well, but my wife wanted to go hiking this morning, and happy wife happy life, so I canceled immediately and rebooked for tomorrow.
I see that all time slots on all three days are completely booked and 90% waitlisted, great news for Lucid.
10/24/25
Process:
Route:
Extra #1:
Extra #2:
Recommendations:
Thanks for the detailed feedback.
My test drive is on Saturday, May 24th.
Given your experience, I'll visit the showroom on Thursday or Friday morning to experiment with the UI, Seats, and other stuff.
Thanks for the detailed write up. Helps confirm what most of us probably already knew.
1. How does it drive - Great, best in class
2. How does it look - Great, depending on your SUV, Minivan, Station Wagon preferences
3. How does the software work - TBD. The HUD not working worries more than the auto-parking issues.
Moving forward, it will take waiting for actual customer deliveries for some on this forum to do more detailed analysis. Or Kyle in OOS Reviews to get long term loaner. Then we can get info not covered by other Press reviewers so far:
1. How is real world range and charging?
2. How well does ADAS work? I sympathize with you Air drivers that payed for DDP years ago to only have ADAS similar to my 2016 Mercedes.
3. How stable is software? I am more worried about minimal system crashes and door locks working properly than if Apple Car Play or Tidal occasionally act up.
Even so, I look forward to a test drive vehicle to show up in Houston studio sometime soon so I can get a “limited” feel for this car.
A harder question, what did you dislike about the vehicle, other than the parking non-assist? (I've never seen a good parking assist. The closest is Tesla, which I would rank as "sometimes ok".)
The seats, driver position, general ergonomics, even the squircle wheel... all really good.
They fixed many issues I've had with the Air:
  • design of the wireless phone charger
  • position of window switches which in the air tend to have me opening or raising the rear windows when i was trying for the fronts
  • overall size of the front window openings which can make it nearly impossible to reach things like parking garage ticket dispensers or pay machines, drive thru windows, etc. Gravity opening and position of the window vs. my seat position seems to be an improvement.
  • Squircle and the huge main screen make visibility of all the info and displays fantastic
I guess a few things I noticed that I did NOT like, though none were really critical to me:
  • cupholders are still too small... but to be fair, i didn't sit there trying a variety of mugs or bottles that i've had trouble with in the Air... maybe they're slightly improved, but couldn't tell. They're still pretty small in diameter, but didn't check/compare depth or rubber gripper differences, if any. They certainly don't seem best-in-class... but, not a biggie to me.
  • I did notice some visibility issues with the A pillars... probably worse than the Air, but something I've gotten used to on the Air and can work around it in most cases.
    • Rear / side / blind-spot visibility: I should have studied this more, but i fogot to really pay attention. It's possible that rear bisibility might be better despite the longer cabin due to slightly higher roofline? didn't really notice. I'm sure rear corner and blind spot visibility is worse than Air due to huge c-pillar design, but possibly mitigated by technology assist systems.
  • ... and as posted in another more relevant thread, yikes, i hated the look of Yosemite interior... but I'm certainly going to offend people who really want that. Just my taste... and it's not that I don't like white seats/trim. I kinda like it on Teslas, but don't think the Gravity materials and color for Yosemite were as attractive.
that's all i can think of right now, so will be good to hear others' impressions as more people get test drives.
FWIW, I’ve had zero issues fitting any cups into the cupholders in the gravity. Not all *water bottles* fit, but the detents in the doors are deeper than the Air and meant for those. It works well.
... oh, and the new on-screen seat adjustment controls are visually cool, but functionally not so great. In the gravity UI, you physically drag the seatback forwards and back on the screen, and there's a lag with the motor vs. what you're seeing on the screen... so I don't think it's an improvement over the way it's done on the Air. But I'd never really use that so i didn't care that much, as the physical controls on the side of the seat are just so much easier and are a decades-long solved problem.
very glad to hear this! thx!
Can’t believe you lumped us Air Pure drivers in with the ICE drivers. That disappoints.
ha, yeah, that doesn't seem quite right! :)
Thanks for the awesome write up! You will live in our memories forever as the first forum test drive...
My SA is on vacation until the 1st so I'm trying hard not to text until he gets back asking when they're going to have one here in MA.
Details, pictures?
My opinion after driving a Gravity GT this morning (I've owned an Air GT for 2.5 years): it's clearly Lucid 2.0, everything I could touch or see is noticeably improved over my early GT. Extremely comfortable and quietly luxurious. The squircle steering wheel was a non-issue. The vehicle looked less like a minivan than I'd remembered.
I had been cross-shopping Gravity against the less-expensive Polestar 3, but had an opportunity to spend time with both in the same hour this morning. I'll no longer be considering the Polestar - Gravity is more elegantly luxurious, more comfortable, much more spacious, with better interior materials. The only advantages the Polestar has are a more athletic look and native Google maps. It was clear to both my wife and I that Gravity would be a nicer vehicle to spend time in. Nothing wrong with the Polestar, it's just a different class of vehicle at a lower price point.
So I'm all-in on Gravity, but will delay my order until HUD is again available. Maybe switching to Titanium or Bronze paint will be enough. I'll talk to my sales advisor about it when they call. By that time, Lucid should have a clear process for those willing to wait for HUD.
I saw the Gravity at the December delivery but haven't driven one. Your write-up convinced me to place an order.
Probably the only one in last 24 hours :cool: but doing my part to support Lucid.
Will also ask to delay until HUD is available.
When I mentioned that I was set up for a test drive tomorrow (Saturday), the Lucid employee said that the test drive wouldn't allow for me to go on the highway. I mentioned that I had heard that the route was up the highway one exit and back on side roads and they said "Yes, we saw that posted and don't know why they said that". Ummm, huh?
I'm going to ignore the fact that she implied that the OP was not telling the truth, but did anyone more recently than the OP get to take it on the highway?
I should also add that the same employee said that they have no word on why the HUD is not being available on GT and speculation about supply chains and such would be premature (I didn't mention any of that, she proactively told me not to speculate about something I hadn't even brought up) - another indication that she wasn't well informed about any of this.
