World first: After market wheels/tire, 22” square wheel setup
Based on standard OEM wheels, I'd guess 9.5 inches for right and 10 inches for left.
Stock tire on the right is 285mm wide, how wide is the left?
Full tire size for stock is 285/45/21
Left side is also likely 285mm wide.
Many 285mm tires can fit wheel widths from 9.5-11 inches.
Killing all the fun…the Lucid stock tire is a 285 with road patch at 8.6” while the left tire, while also a 285, has a road patch of 10.4”
Thinking of going Porsche handling route by upsizing to 295/315. Maybe with this wheel. And a summer tire, undecided as of yet.
295 front tire - another first.
Here it is next to Lucid 22/23 setup
For those who weren’t around to do the math, it’s 295 front and 285 rear on 22x10 on Michelin All Season 4 tire
Dumb question: isn't it more typical to have the wider tire on the rear? What motivates this choice? How would you expect wider on the front to impact the vehicle dynamics?
  • Like
Reactions: 037
Pro:
1. Better handling and braking due to increased grip (usually not necessary in lower powered vehicles due to lower limits or less weight)
2. Makes it look bad @$$ - evens out front and rear dimensions
Con:
1. Higher chance to hydroplane in the rain
2. Higher chance to follow grooves in the road
3. Efficiency drop
The basic idea was to give me better stopping and handling to balance out the absurd amount of power.
The braking part needs a new 70-0 test. Will share when I find a spot.
Last result was 160ft for 265/285
First Gravity to record 100-0mph on 295/285?
I may have done a few more 70-0 to be sure…
happy to report no brake fade or drama of any kind, not even brake smell.
I was a little terrified of 100-0 but it was a complete non event.
My Lincoln was only good for one stop before clues emerged the second may kill you.
