- Jan 4, 2022
- Santa Clarita, CA
- 2026 Gravity Dream
- Gravity DE Number
- 68
- AWNJLGKT
I'm still skeptical and just because you can push it to 11C in testing doesn't mean that will ever happen in the real world due to maintaining battery longevity etc. Also, the tests are still conducted in a very controlled scenario and don't reflect real world use. I'm sure other companies making Solid State batteries can yield the same results on internal testing but they've stated numerous times that's not the problem. The challenge has always been about getting it in the real world and scaleable.Donut Labs has just released an independent report on their new battery. According to Donut Labs, the first independent test of the Donut Solid State Battery (see link), conducted by VTT Technical Research Centre of Finland, evaluates its charge performance under demanding conditions without active cooling. The cell was tested at both 5C and extreme 11C charge rates, confirming previously stated fast-charging targets, including a 0–80% charge in just 4.5 minutes at 11C. The results demonstrate exceptional charging capability alongside stable thermal behavior, providing verification of the battery’s high-power performance.
• VTT testing confirmed the Donut Battery charges from 0–80% in 4.5 minutes at 11C rates without active cooling
• The battery retained 98.4–99.6% of charged capacityafter rapid charging at extreme speeds
• No special compression or active cooling is required, simplifying battery pack design and reducing costs
• At 5C charging rates, the cell reached 100% in just over 12 minutes with full capacity available on discharge
I Donut Believe - Presenting Third Party Results
The place where independent analysis of Donut Lab’s solid-state battery claims, with public test data, reports, and technical commentary is released.idonutbelieve.com
Every Monday, Donut Labs will release results of VTT's testing of its battery. If the independent testing confirms Donut Labs claims, this battery will revolutionize EVs.
QuantumScape on the other hand has delivered 4C charging and shown the battery retaining 95% health after 1000 charging cycles
QuantumScape’s solid-state battery cell achieves milestone in testing: 1,000 charging cycles
In recent A-sample tests at the laboratories of PowerCo, the Volkswagen Group’s battery company, a solid-state battery from QuantumScape achieved more than 1,000 charging cycles while retaining more than 95 percent capacity. This translates to a potential battery life of 500,000 km with no...
