Update 2.6.16
YMMV as always. But this update was a massive improvement to Drive Assist for me. No more slowing on sharper curves. Keeps the lane much more effectively. And just smoother all around. Big shout out to the ADAS team.
Yep, same here. It didn't ping pong around in the lane. The biggest change for me on the curves it didn't feel like it was going to hit the wall.
It had some issues handling lane merges and other irregular road markings. But if it wasn't for the take control alerts I'd be convinced this was a final product.
It basically did the 4 hr drive with very little input from me.
Got the update this morning. Was surprised it took ~1h30 to install, wasn't expecting this for a robustness update. But so far, so good.
Does this include GT-P and DEs as well for efficiency gains? I've seen those not referenced more and more (makes sense to not confuse folks).
Haven’t driven the car yet but I’m a little disappointed that the update didnt fix the road rash system not working - an issue that was introduced in the last update?
Curb Rash Alert has worked fine for many updates. It isn’t broken. It doesn’t work in low light, so it won’t work at night or in your garage.
If it *never* works, you need service.
My bad….sorry. I only looked at it in the garage and the light was still on. :-(
Haha no worries; it doesn’t work in my garage either, even with the lights on. But outside in the daylight, it works great.
Lane assist definitely better on "full speed" ramps that transition from one freeway to another. I did make the mistake of testing it on a reduced-speed merge ramp without thinking about it... and I will testify that the tires worked really well despite a bit of screaming from them.
- T
- T
Did it slow down/drift out of the lane or just decided to take the corner at full speed and made it?
Any one received update recently? My GT 22 still not, but it uploaded nearly 12gb since update was released.
Just got the update notification.
Really happy about the drive assist updates. Very interested to see the efficiency updates too.
Just last week was averaging 3.5 @ 70ish from NY to PA. Guess I'll do another drive this weekend for funsies.
I drove to State College this weekend from VA in my 22 AGT and got the notification, something told me to wait until I get back home before doing the installed, but I decided against because I read about the DDP improvement and wanted to take advantage of it on my drive back. I did the update and since, DDP will not initiate. Every time that I tried to, I get a message that the front target is missing and when I do to reverse, I get a message that the back camera is unavailable.
I am scheduled to take the care into the service center for issues with me driver door, an issue that I had before the update (the driver door on occasions will not close, I had to drive with it that way multiple times). I took it in a week ago and SC told me that they changed all the four doors' components, only to experience the same issue just few hours of pick up. SC will be looking into the DDP issue during my appointment next week.
Drive Assist was quite clearly about to drift out of lane really fast so I took over, slowed the car, and brought it around…
- T
Just installed the update. On my 40mile mixed round trip run used to get 3.4 to 3.7 the last run was 4.2 after the update.
My update is taking significantly longer. I'm at 1 hour and at 15%.
Check my connection with Ookla and I'm at 1451 Mbps.
Sadly, no much-needed 5-band EQ on this one. Shucks.
I've had similar results. On a drive I've done several times (2025 AT 20"), I usually struggle to match my overall average of 3.2mi/kWh. Today over the drive I got 3.9!
