- Aug 2, 2025
- Lucid Grand Touring
The primary reason to use scheduled charging is when you have time of use pricing for your electricity and you only want to charge when electricity is the cheapest. In my case, electricity is least expensive between 12:00am midnight and 3:00pm in the afternoon. So, I have Scheduled Charging set to 12:01 am. The first thing to understand is that when the Scheduled Charging (ON) time is displayed in the lower left corner of the Pilot Display the car isn’t necessarily going to wait and then begin charging at that time. If you are more than 200 meters (about 600 feet) away from your Scheduled Charging Location, the car will begin charging (with a short delay) the moment you plug in the charge cable. This makes sense because if you are at a public charger you want to immediately begin charging. In my case, I own two houses and upon arriving at my other house I plugged in the charging cable and when charging immediately commenced, I pressed the button to stop it. Little did I know that when I saw “Charging Stopped” at the top of the screen it was NOT going to begin charging at 12:01am the next morning even though “Scheduled Charging (ON) 12:01am” was displayed in the lower left corner. What I needed to do that first day is set a new charging location and then UNPLUG the charge cable and PLUG it in again. Afterwards, “Charging Scheduled” would have been displayed in large type at the top of the Pilot Display. I have only recently become aware of this status display because I am outside the car when I plug the cable in and hadn’t think to look at the display inside the car. Notice the subtle difference in meaning between “Scheduled Charging” and “Charging Scheduled”.
Another aspect of Scheduled Charging is the grace period of 12 hours; if you plug your car in within 12 hours of the scheduled start time it immediately begins charging. In my case, if I run an errand and return home before 12:01pm and then plug the cable in charging starts immediately. This is not bad because the car always finishes charging before 3:00pm using cheapest electricity.
I have sent in a request to customer service to allow the charging location feature to be disabled such that Scheduled Charging works anywhere, not just at a specific location. Scheduled Charging is already limited to AC charging and is disabled at DC fast charging. In my case, I don’t foresee using public AC charging. If I do so it is easy enough to override Scheduled Charging. For those who AC charge at work, they would leave the charging location feature enabled.
