- Nov 19, 2021
- Cupertino, CA
- Air DE-P, Gravity DE
- Air DE Number
- 241
- Gravity DE Number
- 013
- Q1BTN5Y3
Ah, yes - salt will corrode. We don’t have much of that here in CA.Yes and no. For the first 4-5 years this will work. Some where in years 7 - 10 the heavy road salt used in the northeast will cause rust to expand the rotor around the outer venting. Eventually this will cause a pulsating pedal. Every brake job I've done was needed to correct this corrosion problem not to replace worn pads.
