The Insane Collapse of The "Tesla Killer"
Waymo ran over a cat. They didn't know about it until the bodega owner complained about it. Presumably there could always bee something under your car that does not trigger any accident detection, because unlike a human these cars don't use advanced sound as input to detect an accident. It also didn't hear what the human was saying or understand the context o the scenario.
Running over a cat, with all respect to cats, is not a "collision" in the sense we were discussing it and you know it. It is very sad, tragic, roadkill. You know, because presumably you are capable of logic, that that is not a useful claim when discussing detecting collisions, and this is an attempt to move the goal posts.
And again these cars only approximate driving. They are not human. There may never be a need for level 5 because again, we will get good enough at building infrastructure for level 4 that this is not needed.
Right now, you can't even take a snapshot of a road sign and read words on it. Because Mobileye owns a patent on this. Every automaker in the west (except tesla) licenses Mobileye's patent to read a speed limit sign. Tesla uses some alternate method that took them years to develop. Without this you need mapping.
OK? So? License the patent, which is not at all a big deal. It expires in 2030 regardless.
Then understanding words, speech, looking through a car's window to see cross traffic, looking into a car to see someone waving you on, understanding the exact sound of the debris you ran over etc. There's just too much that humans do that a car will just never do.
I do not know what you're on about. Sure, all of this is true, because sensors are not humans. I'm not sure why this is a point worth making.
With current technology, clearly not. You can have a lose suspension bolt and there's no way for your car to know until it falls off.
We were not discussing loose suspension bolts. We were discussing mechanical issues, like, for example, a suspension coming loose. A loose bolt is likely to become a mechanical issue, but that is not what we were talking about. Furthermore, you absolutely can detect loose bolts with current technology, if that was something you chose to do. Luckily, bolts don't come loose all that often, so it is not something we have chosen to do yet. But nothing is stopping us from designing a torque sensor or pressure sensor for it.
And this is not like humans where we drive through every type of failure, get out of the car, take a look at what is wrong, call a tow truck, etc.
Sure it is. If the car is broken, it stops, calls a tow truck, and gets towed to a service center or any local shop. That is precisely how it should work.
Cars are trained on as narrow of a skillset as possible. What you are describing would be part of level 5 autonomy and that's not happening for at least 30 years
You do not need level 5 autonomy to 'call home when broken.' Waymos literally do this today.
That's what VLA models are and some amount of this will be used for support, fleet management, etc.
For example, a LLM will have real-time access to say an X feed, look at a map of a festival, the dates/times it is active, and know to close the roads in the routing software during those times. Everything like that. It will know of police reports, riots, etc. and avoid those areas
Please, please, do not explain to me how AI works. Yes, different model architectures exist for different purposes. That was not the point I was making, and you were not talking about LLMs looking at an X feed. 🙄
Of course you need maps and navigation. Do you need HD maps? No, but you will need to fix all the independent issues the car has, everywhere in the world.
Sure, or you could use HD maps as a prior because, you know, it's useful.
Because you keep ignoring the fact that it costs too many billions of dollars to develop such a system and it costs many billions of dollars a year to maintain this technology.
No, sir, you keep ignoring that: a) technology can be licensed, and, b) technology gets cheaper over time, as training models gets cheaper over time, and more and more datasets become available. Moreover, synthetic data is getting pretty incredible. Your assumption that this will always cost "many billions of dollars" is not as certain as you think it is.
1.5 hr flight is not a 1.5 hr trip.
I see you've never flown JSX.
You will not use a cybercab. You will use whatever autonomous car you own.
No, I won't. I do like roadtrips, so if I'm feeling like a roadtrip, maybe. But I'll probably drive most of it.
Moreover, if I'm traveling for work, which is, and this is important: most travel, then I will definitely not be taking the less efficient route if I can fly.
Do you remember when mythbusters did SF to LA and they found that driving was faster than flying? Do the same thing for a longer distance. What you forget is if you road trip while sleeping, all of this travel time is free, with zero chance of delay.
This is so insanely absurd on it's face I'm surprised you'd even suggest it. "Zero chance of delay"? Surely you've heard of... traffic? Which is, and this is important, a far surer bet than even the already very sure bet of flight delays?
You can make the argument, perhaps, that trains are dead in the world of 'robot cars everywhere,' but to make the argument plane travel is dead? I'd really recommend taking a page out of @gaskiller's book and touching grass for a few days.
This is exactly you failing to understand this like everybody else. They think it's just AI and therefore there is a 2nd mover advantage.
I never said this. Please do not mischaracterize my arguments, and respond to what they are, not what you presume they might be. I try to write very clearly.
And unlike normal AIs you cant just distill, because the inputs are driving data. You can only run self driving on another manufacturer's car, record the inputs/outputs and then imitate what the car does, which will never work beyond very low level driving abilities
Please, please, do not presume to teach me about 'how to break AI.' We can have this discussion, but I promise you, there are many, many ways of solving this problem, even if it is true that, ahem, "you can't just distill."
Mercedes built their own system with the help of nvidia. The performance is mediocre after 6 years of development. They've had ADAS in their cars for years. Tesla is solving some issues that waymo has had for more than 10 years and improving at a fast rate.
All of them...all of them... have issues. Different issues, because they are different systems with different tradeoffs. Your assertion that Tesla is the only one "improving at a fast rate" is untrue.
20 chinese brands all have FSD-like systems. Many of them have 5000+ people working on them. The best one is FSD 12 levels after 6+ years of work.
Cool.
I remember when the most annoying forum member was a curious and intelligent high school student. And he was never actually annoying.
Ah, the memories.
My theory is the guy lost a bet.
Ah, the memories.
This one may be annoying, but for better or for worse, they're effectively driving engagement on the forum!
Take a look at our forum guidelines. It’s perfectly fine to disagree. Personal attacks and treating other members with disrespect is not.
Thank you. I find the semantical gymnastics intended as a personal affront very tiresome. No point debating a subjective topic.
I believe mobileye is not licensing this patent for the purpose of self driving. Which they don't legally have to do. I've seen no evidence of a self driving car ever read a word on a sign. These new self driving systems (aka mercedes alapnmayo) rely on mapping for speed limits. Which then you have the issue that the maps are wrong at the scale where you are driving everywhere in the U.S. Again that's why demo drives in the middle of SF are meaningless. Give it to consumers and see how it performs in the middle of nowhere. In china, when FSD didn't understand local rules very well, the car always outperformed competitors at basic driving tasks and generalizing in rural areas.
There's a video on reddit (can't find it at the moment) of the waymo zeekr going up a hill in SF and at the bottom of the hill before it climbs, it bottoms out and scrapes extremely hard. Easily over $1000 of damage which is the NHTSA reporting threshold and the car does it in the same spot every time. Some of these cars must have done it 100s of times and it's never detected as a collision because sound is not a factor in collision detections
Licensing technology does not work because in order to "license" a self driving system, you have to build a car exactly to the specifications of whatever self driving system you are installing. This is not ADAS and the requirements are more strict. Either you license from someone who knows how to build a car or you don't. Neither is a good option because you're just building the other manufacturer's car at a higher price.
This is a safety critical application where using synthetic data has limitations. The dataset comes from your car, which again you need a car to collect this data.
There's you again not understanding how hard the problem is.
Of course but there are limits on the kind of sensors your car will have. Then the more sensors you have, the more you need to make sure all of those sensors are in working order. Tensor has the most sensors of any self driving car that will be sold to consumers. There are tradeoffs to having that many as the maintenance for that car is likely very high.
Waymo's call home all the time. The issue is the rate that they do it does not work without 10,000 or more remote support agents for millions of cars. They literally have mass freezing events simply because they need too many remote support at times when they don't have enough.
No. Because HD maps are too large to map the entire U.S. This is not a technology that can scale to mapping the entire U.S. as it is many terabytes for a small geofence.
You can't store this on a consumer car. I already explained this many time
Less efficient route is relative. Flying takes time, whereas driving is at night while you sleep.
You would be road tripping in the middle of the night when traffic is generally not a problem. Flights are grounded because of weather, whereas self driving generally works in most weather conditions.
That is not what I'm claiming here. I'm claiming that tesla is improving a ta fast rate relative to waymo. I'm not referencing the others because they are nowhere near unsupervised and they show no evidence of having a path to doing unsupervised.
Again it's you not understanding how hard the problem is because it's a double standard. If you were on the tesla forum (I'm not on there), you can see almost all the detractors left because the argument was always that tesla would never drive using the method they are doing. Waymo for years always said that what tesla was doing was "not possible" and that you could never drive without HD maps, camera only, and that a driver assist system would never morph into a real self driving system.
If you look at other manufactuers you would believe the same thing
Ah, the memories.
@xponents we miss you, can we grab a drink yet or is it still a few years? :p
It’s almost like you could read about it
In part, but not exclusively. You can read about this if you have any actual curiosity.
Irrelevant, as mapping is not the sole method. Also, those maps are generated, in part, by contributions from sign recognition systems, but yeah, it’s probably just a human walking around the US constantly and updating an excel sheet. That makes sense.
Meaningless is a word, but I think you meant “not enough,” which is the actual truth. It is not meaningless, as indicated by the fact that a) it works, and, b) it is a requirement for further development.
Sure, this is the “end game.”
Cool.
A bug? Wild. I never said there wouldn’t be bugs. I said they can absolutely detect collisions. And they can. They are not perfect at it right now. That was not what we were discussing.
That is not true. At all. You can license subcomponents, for example.
This is nonsense. You do not understand how ADAS software works, and this absolutely is an extension of ADAS.
Also, check out Comma.ai.
This is a meaningless statement.
I never suggested it didn’t have limitations. In fact, by virtue of me suggesting it has gotten really good, the underlying implication is that it has, and has had, limitations. Please think about what it is I’ve written for more than 3 seconds.
lol.
Sensors can fail and, this is important, such failure can be detected. This process is called “engineering,” in case you’re curious.
Which is why they are working on stability and robustness so that they can scale with fewer issues. That’s how engineering works.
So they’re not “done”? We may have found common ground! Neither is Tesla, in case you’re curious.
And your assumption that it will always remain this way is misplaced. As technology improves, this becomes less of an issue. We know how to search efficiently through vast piles of data.
This is called, say it with me: “engineering”
Oh? Good to know. I’ll let Waymo know. I’m sure they’d be interested to know about how cars are inherently limited in how much storage capacity they have, by, I guess, @mobada’s decree?
I’m sure they’ll be quite happy to kill off a few open projects and save some money! Thanks!
No, it isn’t relative. A plane flight is inherently more efficient from a time-spent perspective. People have families. Nearly nobody is going to choose a 10hour drive, sleeping uncomfortably in a car, over a 1.5 hour flight.
That is, again, simply untrue. Have you heard of road accidents? To say that there aren’t constant delays when driving is an absurd statement to anyone that has ever, dno, driven any long distances.
Tesla is improving at a fast rate, and they are doing so “in public,” but they are still far behind Waymo in many facets. You are seeing part of the whole picture.
Also, Uber/Nuro is starting driverless rides, so your presumption is, again, incorrect.
Please stop saying this. It has never been true. Saying it more does not make it true, not matter how much you’d like to (intentionally or unintentionally) misunderstand or mischaracterize what I write.
The only double standard is in your presumption that somehow Tesla has it “figured out” and that “nobody else can.” I’m paraphrasing, but not inaccurately based on what you’ve written.
I understand you’ve picked a horse in the race. You’re allowed to make a bet. You’re not allowed to assume all other bets are stupid just because it isn’t the one you’ve made.
I do not care about the Tesla forums. I do not own a Tesla. I wouldn’t presume to show up there and pretend I know more about a Tesla than the forum members do. That would be uncouth.
I wouldn’t recommend anyone else do that on this forum either, but your life is yours to live as you choose.
Tesla has yet to prove Waymo (and the other detractors) wrong. You’ll note they have not done any unsupervised or driverless rides yet.
Nor have they applied for any kind of permitting for it.
Wild to think about why, but perhaps we could rely on Occam’s razor here which says… they’re not ready?
I don’t think that’s a problem! I’m excited for competition in this space!
But please stop saying things that are untrue, like Tesla having “proven everyone wrong.”
They haven’t yet.
That article makes no claims about a car having traffic sign recognition for self driving.
Tesla seems to have invented an alternate method that gets around the mobileye patent. Tesla also seems better about identifying words on the road (vs road signs) which makes me think this is due to the patent only covering road signs.
Tesla is good about seeing arrows on the road, identifying "keep clear" area around fire stations, etc.
HD maps is a different method of driving. You map using 360 degree lidar and generate point clouds of everywhere you can drive. These point clouds are synced to lidar outputs in real-time to give you a centimeter accurate position of where you are. Otherwise you rely on innacurate GPS.
This is presumably not usable to the full extent without having 360 lidar on cars
This is no bug. It is purely a limitation of accident detection. You don't have sensors everywhere.
Secondly, the scraping of the car is an HD mapping failure. Which then means your HD map needs to be modified on a pure-car basis for limitations in vehicle geometry, sensor placement, etc.
Waymo barely lasts 100 miles on a charge. They never had any intention to do large geofences or road trip between cities, because to them, the tech is not there.
This is just a simp
Comma.ai is not a self driving system. It's not a safety critical system operating at an unsupervised capacity. There is a clear difference
Really good is not the same as doing it at a safety critical level whicy you don't understand
You're not understanding the limitations of hte technology we have now. Waymo has limitations. The car with some of hte most sensors in the world has some pretty significant limiations. Now certainly they will look to reduce sensor count overtime. The limitations will always be there.
What you seem to lack an understanding of is that these cars will simply have limitations. It's just how self driving works.
Road accidents would again be prevented by a self driving car. What are the 3 causes of traffic? Improper merging, traffic ripple, and accidents. Self driving cars prevent all 3.
Nuro driving is meaningless. Untill we actually see a non-timelapse drive, we don't know how well they drive.
There's also a reason most self driving companies (Nuro, Zoox, etc.) do san francisco first. What looks "impressive" or "hard" is actually easier. There's a reason doing austin like tesla did is much harder. The speeds required are much higher, the geofence needs to be much larger, and you need more intelligence. At low speeds you can rely more on emergency braking to fix issues.
They haven’t yet.
Are you not paying attention? Tesla literally has 2000 vehicles right now and is scaling and they just added 285 vehicles this week. They have about 1000 cybercabs currently heading to miami, phoenix and vegas right now.
They are currently operating in weather conditions waymo won't operate because last week they had a mass freezing event in miami/SF at the same time for flooding issues. Rider support asked someone stuck in flooding to climb out the window. Tesla's flood handling with v15 is really, really good. Makes waymo look embarrassingly bad.
Tesla also updated their emergency response plan for L4 to include california and at the rate tesla is scaling they will probably have around 3500 vehicles this year.
Waymo only has 4488 vehicles and they have been artifically pumping vehicles into texas to make it look like they are scaling, meanwhile every new city has a smaller and smaller geofence.
Tesla is the opposite and every new city geofence is bigger than the last. Dallas fort worth alone will be close to 2000 sq miles which is bigger than waymo geofence across all cities
Tesla is also in parallel currently planning to launch 45 cities. A few of them are one metro like DFW, so 40 cities, about ~500 cars average per city is around 20K.
By comparison, waymo seems to be having too many problems with the vehicle scale they have now.
Lucid is on year 4-5 since first delivery. It’s like Tesla was in 2016 when nobody was buying model S because it was $150k.
Sorry, but I cannot agree with your statement regarding noone buying Model S in 2016 due to 150k cost.
I bought a new Tesla Model S 90D with autopilot, optional opening glass roof, and upgraded interior for just over 100k, so not the 150k you quote. Not the top of the line, but not a base model either.
And I was not the only one that bought a Tesla in 2016. Tesla actually sold more Model S vehicles in 2016 than they had in any year prior. If you look at just the Model S sales in the US, Tesla sold just under 29k Model S in 2016. Compared to Lucid selling about 9k total vehicles in the US for 2025, Tesla 2016 sales look pretty healthy to me.
While I'm on my second Telsa Model S, having logged 75k miles on it in just under 3 years, it's likely my last Tesla (neither the Model 3 or Y have ever excited me). I joined this forumabout a year ago as part of learning/researching Lucid in case something happened to my 2023 Tesla MS. Unfortunately the state of the Lucid service network is a big barrier for me with the two nearest service centers each being ~230 miles and 3.5 hours. Yes, I'm aware of mobile service. I relied on Tesla mobile service for about 1.5 years after I bought my 2016 Tesla when the nearest Tesla service center was 100 miles away at that time. But I'm not seeing any signs of growth over the past year which is a key part of my hesitation to embrace the Lucid brand.
Look into BMW as well they’ve come a long ways. But they are also basically the gas car with an EV powertrain. For better or worse.
No, that's coming up real soon.
Our beloved forum member is in the midst of his transitioning, from my last conversation with him a few weeks ago -- hope he doesn't mind my sharing the info/progress.
This is just a simp
I know you seem to think that more words means you are more right, but making assumptions about the knowledge your partner has is not a great idea. There’s a saying about how those who assume.
This has, yet again, turned exhausting to correct, and so you can have the last word again. But suffice it to say that between the two of us, there’s only one that has leaned toward assumptions and conjecture rather than evidence and facts.
And that’s fine. Have a lovely holiday season.
think about it. LA to atlanta is 32 hrs of driving. Sounds like a lot. But once you consider about 10-12 hrs of sleep/watching TV or doing mindless tasks a day, that's only about 16 hrs of active traveling
Everyone will have this tech because it will be like owning a cell phone. Why waste half a day to fly somewhere for the weekend (and half a day flying back) when you can just do it overnight and waste no time at all?
Or our country could join the 20th century and get high speed electric rail and have none of this nonsense.
