A J1772 adapter is only for AC charging.The one thing that I am having difficulty with is finding the descriptions on adapters from various manufacturers that state if they support AC charging, DC charging or both.
Electron makes a Tesla to J1772 adapter, 60 amp or 48 amp I believe. So does TeslaTap. For AC charging (home, level 2 at hotels, etc.) use only.The one thing that I am having difficulty with is finding the descriptions on adapters from various manufacturers that state if they support AC charging, DC charging or both. Further complicating the situation are the different generations of AC level 2 Tesla destination chargers. Mine is third generation which seems to not be compatible in many cases.
@David R. when you said above, 'The other Lectron NACS to J1772 adapter that is available should work in your house to charge the Air via Level 2 charging,' are you referring to the Lectron J1772 to Tesla Adapter 80 Amp adapter?
I chose to buy 80 amp adapters because some older Tesla destination chargers at hotels can and will furnish 80 amps to the Air. I wanted to be able to safely use the adapter while traveling.Electron makes a Tesla to J1772 adapter, 60 amp or 48 amp I believe. So does TeslaTap. For AC charging (home, level 2 at hotels, etc.) use only.
Currently, only Tesla supercharger stations with built-in Magic Dock CCS adapters will work with the Air. These are very few and far between.Can you recommend an adapter to use with Tesla superchargers (the few that are open to us as of now...despite promises...)
It seems that most of the current large DCFC charging infrastructure projects have chosen dual cable charging stands with both CCS and NACS connectors. So I think driving a CCS vehicle will get better in the near future, rather than worse. Good idea to have a NACS adapter anyway though.I have a J1772 adapter for using destination chargers. With the 50kw limit and expanding charging networks I'm in no rush to purchase a CCS adapter.
A2Z does make an adaptor rated for 500 amps and 1000V. In the future (4-5 years) if more networks switch over to NACS only I will purchase one.
I have both an 80 amp and a 60 amp TeslaTap for that reason.I chose to buy 80 amp adapters because some older Tesla destination chargers at hotels can and will furnish 80 amps to the Air. I wanted to be able to safely use the adapter while traveling.
We just keep an 80 amp TeslaTap in each car. They'll work for any charge rate of 80 amps or below.I have both an 80 amp and a 60 amp TeslaTap for that reason.
Thank you, Deane. I was confused as to why some adapters are J1772 and some are CCS, so your comment is very helpful. I've now ordered a J1772 adapter, so I will test it out and post my results here when it arrives.A J1772 adapter is only for AC charging.
A CCS adapter is only for DC charging
No adapter tested to meet UL and CE safety requirements works for both AC and DC charging, nor will any ever, for electrical reasons.
Lectron 80 amp and A2Z 80 amp J1772 adapters are well regarded and are designed to meet these standards.
I'm using the Tesla Gen 3 to Lectron adapter and it's been good until it recent got hotter down here in my garage. Now after about 30 mins the kw throttles down to about 6-7. It's still fine for overnight I just need to plug it in a little earlier in the evening. But I never had this issue when it was Tesla to Tesla, even in summer.The one thing that I am having difficulty with is finding the descriptions on adapters from various manufacturers that state if they support AC charging, DC charging or both. Further complicating the situation are the different generations of AC level 2 Tesla destination chargers. Mine is third generation which seems to not be compatible in many cases.
I am told that most if not all plugs on Level 2 charger cords have a thermistor or other temp sensing device inside as a safety. I have read some safety circuits will throttle, as you mentioned. Others simple shut off power. I am almost certain I have read that Tesla has always used thermistors in it's home and destination charger plugs. So, it seems from your experience, the Lectron adapter is generating the abnormal heat, not the Tesla plug. And it's the heat from the Lectron and the ambiant heat together causing issues. Not a good sign.I'm using the Tesla Gen 3 to Lectron adapter and it's been good until it recent got hotter down here in my garage. Now after about 30 mins the kw throttles down to about 6-7. It's still fine for overnight I just need to plug it in a little earlier in the evening. But I never had this issue when it was Tesla to Tesla, even in summer.
From all reports, they appear to be bombproof, and worry free. Over engineering, vs Chinese cost cutting.We just keep an 80 amp TeslaTap in each car. They'll work for any charge rate of 80 amps or below.
Following up on my purchase of the J1772 adapter, this adapter does work successfully with my Tesla third gen destination charger.Thank you, Deane. I was confused as to why some adapters are J1772 and some are CCS, so your comment is very helpful. I've now ordered a J1772 adapter, so I will test it out and post my results here when it arrives.
How old is your son's wall connector? My guess is that older wall connectors have a slightly fatter plug than newer ones, and adapter manufacturers weren't aware of this. TeslaTap had a similar issue with their product.bought the Lectron NACS to J1772 adapter so I could charge the GV60 when I visit my son's home. We used it for the first time today and it was somewhat difficult to initially connect his Tesla connector to the adapter but after pushing firmly we were able to get it connected. Then we waited 30 seconds as instructed in the adapter manual and then plugged the adapter into the GV60. Charging started successfully and the car was receiving 7.4 kW which was okay. After the car reached our desired level of SOC we disconnected the adapter from the car but then we had a lot of trouble disconnecting the adapter from the Tesla connector. Yes we did press the button on the bottom of the Lectron adapter but it required extensive pulling to get them apart. This doesn't seem normal to me and I'm thinking I should return the Lectron adapter. Before I do that I thought maybe someone here would have some information that would be helpful??
