- Oct 1, 2022
- Grand Touring
I don't consider myself an audio expert but I do expect to enjoy a great music experience while driving. Despite the hype of Dolby Atmos, Tidal and Lucid's Surreal Sound, I was disappointed, like a few others on the forum, about the lack of punch in the bass. Don't get me wrong, the highs, mids and spatial imaging are stellar indeed but the bass need attention, in my humble opinion.
Below is my novel solution: I purchased an enclosed self powered 12 inch JBL subwoofer from Amazon. I originally intended to place it in the frunk but ran into too much difficulty plumbing the wires from frunk to cabin so instead I placed it bottom enclosed part of rear trunk.
I took the power supply from the right sided 12v outlet. It is switched meaning power shuts off about 30 seconds after you lock the door and walk away from the car. To access it just pull the trunk liner straight up and take a parallel feed.
I removed the trunk liner just behind the rear seats to expose the Lucid subwoofer below rear package shelf- use screw driver to pry out plastic plugs
This gives access to subwoofer's wire leads. I used two aligator electric clips to take a parallel feed to the JBL subwoofer. I did not cut lead or disinstall native Lucid woofer. At some point I should probably go back and solder them...
Next I turned my attention to the trunk partition cover as is was now touching the JBL subwoofer below. I cut and installed plywood in the same pattern as the partition cover to clear the subwoofer's elevation and yet not have the partition cover slide around
With the modified partition hovering about the subwoofer, everything looks relatively factory stock
The sound is now truly phenomenal and bass notes, whether one is seated forward or aft, are exactly what you would expect of a car of this price. This was a low cost (<$300) endeavor and took me a day to complete. Hope others will find this of benefit,
Now if the weather will cooperate.....!
best
Sameer
best
Sameer
