From the LCHCS manual, sounds like an issue with the battery board. Perhaps you forgot to pull the little tab, or could be a bum unit? It doesn’t actually need batteries for residential use. See below:Hi, has anyone had a hardwired Lucid charger that only shows as solid orange? Is goes from slashing white to solids orange without updating. What could be that issue?
Did you install battery in the charger? My understanding is battery is NOT needed.Hi, has anyone had a hardwired Lucid charger that only shows as solid orange? Is goes from slashing white to solids orange without updating. What could be that issue?
Thanks, my installer saw that but we couldn't figure out what the Battery Board is. We called Customer Support and they didn't have much to offer. Said let just keep it on and it will start charging. We're going on 6 hours, so I don't think so. May have to exchange it.From the LCHCS manual, sounds like an issue with the battery board. Perhaps you forgot to pull the little tab, or could be a bum unit? It doesn’t actually need batteries for residential use. See below:
I’d contact customer support.
NoDid you install battery in the charger? My understanding is battery is NOT needed.
Yeah, that sounds like the likely solution. Sorry you’ll have to swap it!Thanks, my installer saw that but we couldn't figure out what the Battery Board is. We called Customer Support and they didn't have much to offer. Said let just keep it on and it will start charging. We're going on 6 hours, so I don't think so. May have to exchange it.
