Here are the pics of the install. I ended up doing 2 things.
First I ran an extension cigarette cable from the trunk, through the cabin, to the front, by the passenger side of the center console.
I pulled the back seat cushion up to hide the wire and keep it pretty clean. And to make sure it didn't catch if the seat was lowered. You can see the wire at the top of the image. You can also see the battery in the cabin. That is the one that is connected to the rear rear well for jumping.
I ran the extension cable along the other cable and secured it. Then ran it under the mats to the front passenger area. I didn't feel like fishing the line under the carpeting.
Then I started working on the antenna. For now, its placed in the back under the passenger moonroof until I find a better position. The Red line is the course of the cabling, not the cable itself. The cable it black.
I removed the side trim by removing the 2 10mm nuts holding that piece in place. Then I tucked the wire under the trim with tools shown up to the front, under the glovebox, to the cigarette adapter.
Initially I wasn't getting good signal from the antenna, but then I realized I had pointed it the wrong way. For now the antenna position has been working out well. I'm probably going to 3d print a piece to position the antenna more discreetly. I was just testing positions for now.
Hope that helps.
I can start a new thread with this if it will help others.
