Roof rack plus single bike mount
Demosthenes
In case anyone was curious about them.
Easy to install, not bad looking, seem strong. I do notice some additional wind noise from above while driving though. Seems not to impact range.
Nice. Look perfectly integrated into the design.
I'd love it if I could figure a way to carry my ebikes with my Lucid but they weigh ~60lbs each and would need to be on a hitch
What has been the range hit with the cars mounted on the car?
Can you install just one of those roof rails instead of two?
Yes you can put just one if you like. I am not sure what it will accomplish though.
I think the rack is rated to carry an ebike load, but I could be wrong.
Anyone use this for installing a Starlink device on their Lucid. Seems doable with these roof rails. People have done this kinda setup on other cars
Noticeably more wind noise at high speeds. Reasonably easy to install and de-install but still require basic tools.
Hi - you seem to be one of the few people on the forum that has installed and used the Lucid roof racks without problems. Are you still happy with them? Ever mounted two bikes at same time? Thanks.
For what it's worth, I talked to a few of the higher-ups about this issue at an event. According to them, the reason there hasn't been another revision is because the vast majority of people have faced no issues with them. I haven't used them, so cannot speak from personal experience.
They did remark, however, that if you have a glass roof, they highly highly highly recommend getting it installed by service.
Most people must be using road bikes or only one bike... A single mountain bike may be doable, but two was not a pleasant experience.
I can't speak from experience; I've never tried it. Just relaying hearsay, that's all.
