Rear view camera view
Magneto
2025 Lucid Air Touring: The rear view camera seems to capture a huge shadow coming from the rear spoiler. Is this usual or my rear reverse lights are not functioning. Your feedback is appreciated. Picture for reference
Looks normal
The camera is working as expected, but the digital alignment is off. Each camera is very wide angle, and when they perform a camera calibration and alignment they digitally set the zoom and cropping on each camera so that they look correct.
I know this because a long time ago a software update caused all of my cameras to reset (presumably the update accidentally corrupted or otherwise cleared the alignment data). I reported this problem to Lucid, who didn't believe that an update could screw up the cameras and refused to redo the alignment. I lived with it for a few months, and eventually a camera had to be replaced and they then did a full calibration/alignment, and everything looked good again.
I think you're misinterpreting the image. The white semi-circle is not light from your reverse lights or any other source; that's a visual depiction of the ultrasonic sensor range, and its associated Curb Rash Protection, and/or distance measuring capability. As you move the vehicle closer to objects, the white corona will turn yellow and red to indicate proximity, and its shape will change accordingly.
