- Jan 21, 2023
- Air Touring, Ioniq 5
- OWLPTRZ3
I have a new Plug & Charge issue and wondering if it related to EVgo's Autocharge or is it just random.
I've used P&C loads on my car as I drive from SF to LA about once a month and use it on those drives. I also use it occasionally on EA DCFC around my home when the opportunity presents itself. Occasionally P&C will fail, but when that happens I'll get a notification on my Lucid app. When that happens, following the prompts has always worked.
That's not happening now.
Elsewhere in this forum I wondered aloud if P&C sudden failure was related to my recent 2.1.47 update, but others assure me that they've been able to use P&C since updating. So it has me wondering what else it might be.
Since the last time I successfully used P&C I tried to enroll my car to EVgo's autocharge+. Newsflash, autocharge+ doesn't work and I suspect it might because the P&C certificate is "getting in the way" somehow. To be clear, there is no similar autocharge+ certificate installed on the car like P&C. It's all done with the EVgo app, and reading the car's VIN (I think it is the VIN it is reading). Regardless, after staying on the phone with EVgo for about 30 minutes I decided it wasn't worth the hassle, so, when I use EVgo (not very often) I'll just use the app like everyone else.
BUT!
As of today, Plug & Charge has stopped working on my car. Not only has it stopped working, but the planned "fail over" scenario of starting the session via Lucid's app no longer works, either. Not sure if it has anything to do with trying to enroll my car on autocharge+ (I can't see how it would, but hey, who knows) of if this is a red herring, and the P&C problems are completely unrelated.
I'm wondering if anyone:
1- has successfully enrolled their car on the EVgo autocharge+ feature> and/or
2- Has experienced P&C failing after months and months of being flawless.
(More background) When I plug in to an EA station, I would expect about 30 seconds and then the station and car both confirm a charging session has started. Now after about 60 seconds the car, the station and my Lucid app all say that the session has failed and requests that I try again. I would expect the app to give me a prompt for a failed P&C session, as it has in the past, but no joy there. I've successfully used the station where I had the problem. I tried two different stations (at the same location), 3 different plugs over 5 or 6 attempts. Ultimately, EA started the session for me.
I have an open ticket with Lucid.
Thanks!
BUT!
Thanks!
