Pilot Panel not turning on car is inoperable
djstone713
Lucid Air Pure
The pilot panel is blank and not not on making the car is inoperable. Ive tried the logo reset, Bobby reset and I believe nuclear reset and nothing won't turn it.
Unfortunately it's Christmas Eve and we are stuck and Lucid is closed.
Any other suggestions?
The pilot panel doesn’t make the car inoperable, and you couldn’t have tried the logo reset if it is inoperable. The pilot panel is the center panel by the center console, not the screens in the driver’s console in front of the steering wheel.
The infotainment reboot (aka “nuke” reset) should resolve this; instructions are here in the manual: https://publications.infotainment.p...tml#GUID-DC7897DB-9B32-4980-A0CE-E68F4DB18357
If that doesn’t work, try letting the car fall completely asleep (give it 20-30 minutes, with no fob or phone nearby), and then wake it up again.
If that doesn’t work, you need service.
Thanks the drivers panel is not working... will look at instructions.
Leaving the car alone and fall asleep seemed to work.
Strangely, I received an alert that my trunk was open. Went to the car, trunk somehow opened up (it wasnt open before) and I had to manually close it as the button for automatic close wouldn't work. The drivers screen turned on after.
Very strange, but appreciate the help.
Automatic close won't work if the trunk is open for an extended time. You will need to close it manually. This is also detailed in the manual. It's a good idea to give it a thorough read while sitting in the car and trying things.
In that case, how did you try a Bobby reset? That is initiated on the driver's display.
