OTA Update 2.7.0
We have tried different Wi-Fi networks with no change in wake up performance
Is your phone set up as mobile key? Are you relatively close to your car? I can’t use mobile key because A: it crushes my phone’s battery, and B: the car will never wake up via the app
With regards the brake issue our car now rolls in either direction when stopped depending on the pitch of the road. I will try to reset the software if I can follow the instrctions but why did 2.7.0 change the settings we had?
Regarding "Wake Up" our car always woke up as one would expect until the OTA update prior to 2.7.0. Since then it will not wake up at all. Very upsetting & again why do these updates always change existing settings? I've had it with this vehicle!
So it’s set to “Vehicle Hold” and it still rolls forward and back??!! Honestly I always do a software reset after an update because things tend to behave weirdly until I do.
Ok .. I'm putting this out there ..I've been waiting for AA just like everyone else...but today I found myself turning it off and switching to Lucid native apps and maps...they're simply more aesthetic to my eyes and work just fine ...I....disabled ....AA...what a circle of life...
I leave AA connected but use Lucid's UX. The streaming Tidal quality in AA was a game breaker for me but once someone posted you can use AA and the native Tidal app, I decided I'd just turn off the music automatically starting in AA and keep it in the background. I like that you can switch out of AA with a simple tap if the home button or Lucid button in AA.
And why would the DNS be an issue.
If your DNS server’s ad blocker, for example, is blocking a domain Lucid uses, that could cause failure.
Anyway, sounds like that isn’t it.
With regards the brake issue our car now rolls in either direction when stopped depending on the pitch of the road. I will try to reset the software if I can follow the instrctions but why did 2.7.0 change the settings we had?...
Did you check the Vehicle Hold setting in your car's settings menu?
It's rare, but I have heard of this setting being changed spontaneously by a software update.
Does anyone know how to have AA display the home screen instead of music and Google Maps on startup? I've looked over the settings on my phone and in the car and nothing.
Also, I like Google Maps in dark mode all the time and after I changed the settings to dark mode in Google Maps on my phone and in AA, it still reverts to light mode upon startup. Any suggestions.
i remember seeing something about widgets in the AA app on my phone. i did not go inside the option so i'm not sure what's available.
